[Ovmsdev] Developer Manual?
Michael Stegen
michael at stegen.com
Sun Apr 22 16:44:26 HKT 2018
Mark,
Copying support/sdkconfig.default.hw31 to sdkconfig fixed the issue, thanks!
-Mike
Op 21-4-2018 om 16:46 schreef Mark Webb-Johnson:
> Can you try copy support/sdkconfig.default.hw31 to sdkconfig to give a standard set of defaults (those used for production). You will then need to adjust the UART path appropriately.
> Also, please ‘git pull’ on each of the projects, to make sure you have the latest sources.
>> On 21 Apr 2018, at 10:30 PM, Michael Stegen <michael at stegen.com> wrote:
>> Steve,
>> Thanks for your suggestion.
>> I tried it ( git submodule update --init) and it did install mongoose in the correct folder.
>> However, as you already noticed, this was not the solution to the problem.
>> Exact same error also happens on a Ubuntu 16.04 installation i did.
>> I'm clearly missing something... but what?
>> -Mike
>> Op 21-4-2018 om 8:43 schreef Stephen Casner:
>>> Mike,
>>> Separately cloning mongoose is not the usual procedure. Normally it
>>> is just "git submodule update" after cloning OVMS. That is not an
>>> explanation for the compilation error you encountered, though.
>>> Something else is missing.
>>> -- Steve
>>> On Fri, 20 Apr 2018, Michael Stegen wrote:
>>>> Hi OVMS v3 devs,
>>>> In preparation of receiveing the module, i'm trying to compile what's
>>>> currently on github.
>>>> But while doing so, i'm running into problems
>>>> I did the following:
>>>> Install the toolchain (windows)
>>>> cd ~/esp
>>>> git clone --recursive https://github.com/openvehicles/esp-idf.git
>>>> cd ..
>>>> git clone https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3.git
>>>> then in the /components/mongoose/ folder did:
>>>> git clone https://github.com/openvehicles/mongoose.git
>>>> It now does compile up to the following error message:
>>>> In file included from
>>>> C:/msys32/home/Mike/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/simcom.h:34:0,
>>>> from
>>>> C:/msys32/home/Mike/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_peripherals.h:67,
>>>> from
>>>> C:/msys32/home/Mike/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/esp32can/src/esp32can.cpp:42:
>>>> C:/msys32/home/Mike/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/gsmpppos.h:63:5:
>>>> error: 'ppp_pcb' does not name a type
>>>> ppp_pcb* m_ppp;
>>>> C:/msys32/home/Mike/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/gsmpppos.h:64:18:
>>>> error: field 'm_ppp_netif' has incomplete type 'netif'
>>>> struct netif m_ppp_netif;
>>>> Any idea what i'm missing?
>>>> -Mike
