[Ovmsdev] Initial experience and Nissan Leaf updates (was: Turned off commenting on the OVMS v3 User Guide)
Robin O'Leary
ovmsdev at caederus.org
Fri Apr 20 04:19:16 HKT 2018
On Thu, Apr 19, 2018 at 11:23:15AM -0700, Stephen Casner wrote:
> On Thu, 19 Apr 2018, Robin O'Leary wrote:
> [snip]
> > - 'ssh admin at NEWIP' connects, but then immediately closes the connection.
> As the implementer of the ssh functionality, I'd like to know more
> about what happened here. Does ssh still immediately close the
> connection? If so, can you try 'ssh -v admin at NEWIP' and report back
> the output?
Yes it does, but I've now tried from a few other hosts running different
OS versions with mixed results:
fail OpenSSH_7.7p1 Debian-2, OpenSSL 1.0.2o 27 Mar 2018
OK OpenSSH_7.4p1 Raspbian-10+deb9u3, OpenSSL 1.0.2l 25 May 2017
OK OpenSSH_7.4p1 Debian-10+deb9u2, OpenSSL 1.0.2l 25 May 2017
OK OpenSSH_6.7p1 Debian-5+deb8u3, OpenSSL 1.0.1t 3 May 2016
hang OpenSSH_5.9p1 Debian-5, OpenSSL 1.0.1b 26 Apr 2012
> On the v3.0 hardware with limited RAM, the connection closes
> immediately because the DH handshake fails due to a memory allocation
> failure. But with v3.1 hardware there is plenty of RAM.
Is there some server-side debug I can turn on?
debian 10 (buster) connects but immediately closes:
$ ssh -v admin at chevaline
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to chevaline [...] port 22.
debug1: Connection established.
debug1: key_load_public: No such file or directory
debug1: identity file /home/robin/.ssh/id_rsa type -1
debug1: identity file /home/robin/.ssh/id_rsa-cert type -1
debug1: identity file /home/robin/.ssh/id_dsa type -1
debug1: identity file /home/robin/.ssh/id_dsa-cert type -1
debug1: identity file /home/robin/.ssh/id_ecdsa type -1
debug1: identity file /home/robin/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/robin/.ssh/id_ed25519 type -1
debug1: identity file /home/robin/.ssh/id_ed25519-cert type -1
debug1: identity file /home/robin/.ssh/id_xmss type -1
debug1: identity file /home/robin/.ssh/id_xmss-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_7.7p1 Debian-2
debug1: Remote protocol version 2.0, remote software version wolfSSHv1.1.0
debug1: no match: wolfSSHv1.1.0
debug1: Authenticating to chevaline:22 as 'admin'
debug1: SSH2_MSG_KEXINIT sent
Connection closed by chevaline port 22
The relevant section of /etc/ssh/ssh_config says:
Host *
SendEnv LANG LC_*
HashKnownHosts yes
GSSAPIAuthentication yes
Raspbian 9 (stretch) works OK:
debug1: identity file /home/robin/.ssh/id_rsa type 1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_7.4p1 Raspbian-10+deb9u3
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: diffie-hellman-group-exchange-sha256
debug1: kex: host key algorithm: ssh-rsa
debug1: kex: server->client cipher: aes128-cbc MAC: hmac-sha2-256 compression: none
debug1: kex: client->server cipher: aes128-cbc MAC: hmac-sha2-256 compression: none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(2048<8192<8192) sent
debug1: got SSH2_MSG_KEX_DH_GEX_GROUP
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: got SSH2_MSG_KEX_DH_GEX_REPLY
debug1: Server host key: ssh-rsa SHA256:2bW5kEnFXZ+ORn3PB00qJa7jRsKkW8zSTyXTuECvVfo
The authenticity of host 'chevaline (...)' can't be established.
RSA key fingerprint is SHA256:2bW5kEnFXZ+ORn3PB00qJa7jRsKkW8zSTyXTuECvVfo.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added 'chevaline' (RSA) to the list of known hosts.
debug1: rekey after 4294967296 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Offering RSA public key: /home/robin/.ssh/id_rsa
debug1: Trying private key: /home/robin/.ssh/id_dsa
debug1: Trying private key: /home/robin/.ssh/id_ecdsa
debug1: Trying private key: /home/robin/.ssh/id_ed25519
debug1: Next authentication method: password
admin at chevaline's password:
debian 9 (stretch) works OK:
debug1: Local version string SSH-2.0-OpenSSH_7.4p1 Debian-10+deb9u2
debug1: Host 'chevaline' is known and matches the RSA host key.
debug1: Found key in /home/robin/.ssh/known_hosts:45
debug1: Authentication succeeded (password).
debian 8 (jessie) works OK:
debug1: Local version string SSH-2.0-OpenSSH_6.7p1 Debian-5+deb8u3
debug1: kex: server->client aes128-cbc hmac-sha2-256 none
debug1: kex: client->server aes128-cbc hmac-sha2-256 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<8192<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug1: Server host key: RSA 9b:91:8b:85:00:77:7e:87:a9:5d:60:f6:2a:83:dd:c6
RSA key fingerprint is 9b:91:8b:85:00:77:7e:87:a9:5d:60:f6:2a:83:dd:c6.
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug1: Trying private key: /home/robin/.ssh/id_rsa
debian 6 (squeeze) fails in a different way; it just hangs:
debug1: permanently_set_uid: 0/0
Desc: Digital signature
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180419/dcfe4165/attachment-0002.sig>
