[Ovmsdev] Initial OTA update
Wed Apr 18 18:35:05 HKT 2018
Am 16.04.2018 um 22:16 schrieb Michael Balzer:
> I have seen the queue overflow problem once on the current build, so it isn't solved. But it wasn't related to any action, it happened while
> the module was idle.
> To clarify, it's no problem if it resolves after some seconds, that may be due to a temporary mongoose lock / overload. If we can trigger that
> reliably by some action, that would help to track this down.
Short update: I could trigger it again now multiple times on the OTA page. It seems to be happening due to the update check running over the
modem line, it does not happen with modem disabled. I need to check in Wifi client mode.
