[Ovmsdev] It's Here!
Sat Apr 14 22:09:40 HKT 2018
> The unit looks really nice, though it seems that the top shell is a tad
> too wide and overlaps the bottom piece by nearly a mm on one corner.
The enclosures are injection moulded, so should be pretty accurate on tolerances. Is it affecting the ability to close the case for you? Or just a slight bulge?
> adhesive on the flap of the padded envelope.
Yeah, the padded envelope is not amazing. It offers protection, but the glue can get everywhere. At least it is easy to remove.
For future production runs, we’re thinking of switching to a cut-out foam box like this. It costs a little bit more, but seems a much better solution.
> My intent is to play "customer" with this unit, only using officially
> released code, updated through typical methods (i.e. not via the
> developer's kit) unless I need to do otherwise.
That would be very helpful.
> On 14 Apr 2018, at 6:49 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Hi Mark,
> The 3.1 module arrived in today's mail. I haven't plugged it in yet,
> but two "unboxing" observations...
> And, not evenly, at that; it's like the corner by the Vehicle connector
> got stretched a bit outward (or the other half pushed inward). The
> other two sides are all pretty evenly matched. The 3.0 proto unit was
> not like this. {shrug}
> Also, the two SMA dust caps seemed to have had some reaction with the
> adhesive on the flap of the padded envelope. They were stuck to the
> flap, pulled away from the connectors (so, not much dust protection),
> and the adhesive on the flap seemed to be very gooey in that area. The
> caps seemed to have been more or less unaffected, so it's more of a
> cosmetic issue. Perhaps they could point the module in the other
> direction (SMA end first), to prevent this in the future?
> developer's kit) unless I need to do otherwise. I've got some
> short-term distractions through the weekend, but will take it out for a
> spin next week.
> Greg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180414/23b8886e/attachment.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180414/23b8886e/attachment-0002.png>
