[Ovmsdev] Crash debugging
    Sun Apr  8 22:11:34 HKT 2018
Michael,
Neat. I agree that the stack track is normally sufficient.
I’ve started to store the production PUSH firmwares in a standardised way. You can find them at:
http://api.openvehicles.com/firmware/ota/ <http://api.openvehicles.com/firmware/ota/>(v3.0|v3.1)/main/ <http://api.openvehicles.com/firmware/ota/v3.0/main/>
<ver>.ovms3.bin
<ver>.ovms3.elf
<ver>.ovms3.map
Where <ver> is the version in format ‘major.minor.sequence' such as 3.1.003.
So, for example:
http://api.openvehicles.com/firmware/ota/v3.1/main/3.1.003.ovms3.elf <http://api.openvehicles.com/firmware/ota/v3.1/main/3.1.003.ovms3.elf>
> On 8 Apr 2018, at 8:56 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
> I've pushed an update to enable saving crash data over a reset and automatically send that to the server using the history record "*-OVM-DebugCrash".
> Note: you will need to pull the esp-idf as well. As the support for exception handlers was insufficient for our needs, I have added a separate error handler
> registration that catches all three kinds of crashes (exceptions, panics and aborts).
> Crash reason, registers (if available) and backtrace are available via "boot status", with "make monitor" automatically mapping the addresses:
> OVMS# boot status
> Last boot was 16 second(s) ago
>   This is reset #1 since last power cycle
>   Detected boot reason: Crash
>   Crash counters: 1 total, 0 early
>   CPU#0 boot reason was 12
>   CPU#1 boot reason was 12
> Last crash: abort() was called on core 1
>   Backtrace:
>   0x4008f698 0x4008f86f 0x400e7027 0x400edb76 0x400edc8d 0x400edc7f 0x400edcb5 0x400e3908 0x400f11c9 0x400f1230 0x400e3937 0x401cb613 0x400e3f49 0x400e82e5
> 0x400e84d1 0x400e3df5 0x400e3e04 0x400e69dd
> 0x4008f698: invoke_abort at /home/balzer/esp/esp-idf/components/esp32/./panic.c:669
> 0x4008f86f: abort at /home/balzer/esp/esp-idf/components/esp32/./panic.c:669
> 0x400e7027: module_fault(int, OvmsWriter*, OvmsCommand*, int, char const* const*) at
> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_module.cpp:823
> 0x400edb76: OvmsCommand::Execute(int, OvmsWriter*, int, char const* const*) at
> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:94
> 0x400edc8d: OvmsCommand::Execute(int, OvmsWriter*, int, char const* const*) at
> 0x400edc7f: OvmsCommand::Execute(int, OvmsWriter*, int, char const* const*) at
> 0x400edcb5: OvmsCommandApp::Execute(int, OvmsWriter*, int, char const* const*) at
> 0x400e3908: Execute(microrl*, int, char const* const*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_shell.cpp:47
> 0x400f11c9: new_line_handler at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/microrl/./microrl.c:620
> 0x400f1230: microrl_insert_char at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/microrl/./microrl.c:668
> 0x400e3937: OvmsShell::ProcessChar(char) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_shell.cpp:70
> 0x401cb613: OvmsShell::ProcessChars(char const*, int) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_shell.cpp:77
> (discriminator 2)
> 0x400e3f49: ConsoleAsync::HandleDeviceEvent(void*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./console_async.cpp:169
> 0x400e82e5: OvmsConsole::Poll(unsigned int, void*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_console.cpp:152
> 0x400e84d1: OvmsConsole::Service() at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_console.cpp:132 (discriminator 1)
> 0x400e3df5: ConsoleAsync::Service() at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./console_async.cpp:80
> 0x400e3e04: non-virtual thunk to ConsoleAsync::Service() at ??:?
> 0x400e69dd: TaskBase::Task(void*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./task_base.cpp:156
> The "*-OVM-DebugCrash" record has this structure:
>     // H type "*-OVM-DebugCrash"
>     //  ,<firmware_version>
>     //  ,<bootcount>,<bootreason_name>,<bootreason_cpu0>,<bootreason_cpu1>
>     //  ,<crashcnt>,<earlycrashcnt>,<crashtype>,<crashcore>,<registers>,<backtrace>
> …with registers and backtraces separated by spaces.
> Example:
> *-OVM-DebugCrash,0,2592000,3.1.003-11-g37c5f4b/factory/main (build idf v3.1-dev-453-g0f978bcb-dirty Apr  8 2018
> 14:42:07),1,Crash,12,12,1,0,abort(),1,,0x4008f698 0x4008f86f 0x400e7027 0x400edb76 0x400edc8d 0x400edc7f 0x400edcb5 0x400e3908 0x400f11c9 0x400f1230 0x400e3937
> 0x401cb613 0x400e3f49 0x400e82e5 0x400e84d1 0x400e3df5 0x400e3e04 0x400e69dd
> To decode the backtrace, feed it to addr2line:
> balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> xtensa-esp32-elf-addr2line -pfiaC -e build/ovms3.elf 0x4008f698 0x4008f86f 0x400e7027
> 0x400edb76 0x400edc8d 0x400edc7f 0x400edcb5 0x400e3908 0x400f11c9 0x400f1230 0x400e3937 0x401cb613 0x400e3f49 0x400e82e5 0x400e84d1 0x400e3df5 0x400e3e04
> 0x400e69dd
> (discriminator 2)
> There is also an option to write core dumps in esp-idf, but a core has 64K, and crashes are still too many. I think the backtrace is sufficient in most situations.
> We should keep a central archive of .elf files for the releases rolled out, so we don't need to recompile for debugging.
> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180408/b82db143/attachment.htm>
