[Ovmsdev] LCD Car Mount Display
Julien “JaXX” Banchet
jaxx at jaxx.org
Thu Apr 5 21:55:41 HKT 2018
On 5 Apr 2018 at 13:52 +0200, Michael Balzer <dexter at expeedo.de>, wrote:
> Julien,
> sure, send me the diff, it's on my list as well, but I also had some trouble with my fullscreen mode tests on elements, so I moved it to the "later" list.
Attached :) used a quick and dirty
git stash list| sed 's/\//\_/g'|sed 's/ /\_/g' | awk -F ":" '{ system("git stash show -p " $1 " >> " $1$2$3 ".diff" ) }’
> My current idea is to fold the nav bar aside instead, or make it vertical in landscape mode. Phones now have a very bad height ratio in landscape, so every vertical space gainable is good.
True, and if fullscreen works, it also gets androids navbar out of the way
Oddly, the little code I jotted down works from a desktop (it triggers fullscreen, not a nice result), but does absolutely nothing on my “oldish” tablet, where http://robnyman.github.io/fullscreen/ does it fine, might have missed something on the way, was tired :)
> For your button, maybe the chart just needs an .update() call after the switch. The SVG needs to be updated on resize as some element offsets and lengths are calculated in pixels. The chart system takes care for standard resizing, but possibly not for a tweak like that.
Ah yes, that’s how I got that funky result on the desktop browser triggering it using the console (which had an unappropriate square ratio, otherwise positioning wasn’t that bad), didn’t add it to the patch yet
JB./.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180405/b60dcfd2/attachment.htm>
Type: application/octet-stream
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180405/b60dcfd2/attachment-0002.obj>
