[Ovmsdev] OTA Automatic updates (middle of the night)
Mon Apr 30 14:32:33 HKT 2018
Yes, a general shutdown signal scheme makes sense, but still also a separate SD unmounting signal to be able to remove just the SD card with a single command.
Am 30.04.2018 um 04:28 schrieb Mark Webb-Johnson:
> Writing the code last night, it seemed that the shutting down of wifi/simcom/etc was messy.
> Perhaps we need to have new signals “ShuttingDown” and “ShutDown”, then make the components responsible for this? So, for example, wifi powers off, server v2
> disconnects, logging stops logging to SD, etc, on “ShuttingDown”. Then SD unmounts on “ShutDown”.
> A better solution?
>> On 30 Apr 2018, at 6:31 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> Attention: performing an AutoFlash just killed my SD filesystem.
>> Possibly just by chance and I was lucky all the reboots before, but I think we really need to close all SD files before reboot -- see issue #97.
>> FYI: the SD could be restored by a simple fsck, no data loss. My Linux system also could mount the SD before the fsck. The module was stuck in the mount attempt.
>> Am 29.04.2018 um 16:39 schrieb Mark Webb-Johnson:
>>> The last piece of the puzzle falls into place.
>>> OVMS# config set auto ota yes
>>> OVMS# config set ota auto.hour 2
>>> Module will wake up sometime between 2am and 3am, and if wifi is available it will check the available server version (according to OTA tag and server url).
>>> If the server has a later version, the module will download and flash that new version then reboot into it.
>>> I’ve also brought in the strverscmp function for GNU library, which is generally useful for comparing versions.
>>> Enjoy.
>>>> Begin forwarded message:
>>>> *From: *GitHub <noreply at github.com <mailto:noreply at github.com>>
>>>> *Subject: **[openvehicles/Open-Vehicle-Monitoring-System-3] 1a4301: Bring in GNU strverscmp component, and test comman...*
>>>> *Date: *29 April 2018 at 10:23:54 PM HKT
>>>> *To: *mark at webb-johnson.net <mailto:mark at webb-johnson.net>
>>>> *Reply-To: *GitHub <noreply at github.com <mailto:noreply at github.com>>
>>>> Branch: refs/heads/master
>>>> Home: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3
>>>> Commit: 1a4301d7ca1c7ed619109dfcb2e832a599af7dda
>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/1a4301d7ca1c7ed619109dfcb2e832a599af7dda
>>>> Author: Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
>>>> Date: 2018-04-29 (Sun, 29 Apr 2018)
>>>> Changed paths:
>>>> A vehicle/OVMS.V3/components/strverscmp/component.mk
>>>> A vehicle/OVMS.V3/components/strverscmp/src/strverscmp.c
>>>> A vehicle/OVMS.V3/components/strverscmp/src/strverscmp.h
>>>> M vehicle/OVMS.V3/main/test_framework.cpp
>>>> Log Message:
>>>> Bring in GNU strverscmp component, and test command
>>>> Commit: 58fa1b57448d3491889e3d1d3f487e475d036c92
>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/58fa1b57448d3491889e3d1d3f487e475d036c92
>>>> Changed paths:
>>>> M vehicle/OVMS.V3/components/ovms_ota/src/ovms_ota.cpp
>>>> M vehicle/OVMS.V3/components/ovms_ota/src/ovms_ota.h
>>>> Log Message:
>>>> AutoFlash implementation:
>>>> Config auto[ota]=yes
>>>> Config ota[auto.hour]=2
>>>> Compare: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/compare/87d80c30825b...58fa1b57448d
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180430/edc9ab61/attachment.html>
