[Ovmsdev] Nissan Leaf updates
Sun Apr 29 18:00:39 HKT 2018
Tom, Robin,
Can you have a look here:
https://www.openvehicles.com/node/209
I tried connecting the OVMS 3 unit to my 2016 Leaf.
The only thing I got working was the battery SOC (flapping between 133% and 30%)
It looks like the unit is sending pre-2016 CAN messages to the car.
I have done som extensive logging of my cars CAN-bus and have all the correct data that is needed to get the following to work:
Wake CAN
Climate control On
Climate control Off
Start Charging
Unlook doors
Lock doors
Instrument SOC
Chargeport open (will be next project)
I have implemented theese codes into a geolink unit, and it works by SMS-commands.
I would like to see this work on the OVMS V3 as well, but my coding skills are limited. I tried to compile the source code but get this error:
/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_boot.cpp: In constructor 'Boot::Boot()':
/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_boot.cpp:159:46: error: 'xt_set_error_handler_callback' was not declared in this scope
xt_set_error_handler_callback(ErrorCallback);
If some of you know how to fix it, please let me know.
If some of you are interested in the CAN-bus messages, let me know and I can provide it.
Thanks, Mark
> On 29 Apr 2018, at 2:48 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Document updated, thanks!
> Greg
> Robin O'Leary wrote:
>> On Fri, Apr 27, 2018 at 09:58:21AM -0700, Greg D. wrote:
>>> Robin,
>>> Could you take a look at the OVMS Metrics Table in Appendix 1 at the end
>>> of the user documentation, and let me know what new metrics should be
>>> checked as supported by the Leaf?
>>> User doc is at
>>> https://docs.google.com/document/d/16JrXR7rybp-18DrEoeh1rg6GqQT_jVBvhaXh2oEWRHw/ <https://docs.google.com/document/d/16JrXR7rybp-18DrEoeh1rg6GqQT_jVBvhaXh2oEWRHw/>
>> I see you have already added Cabin temperature; here are the other metrics
>> I added (*), and some that were there before my additions but not marked:
>> State of charge [%] v.b.soc
>> State of health [%] v.b.soh
>> Calculated capacity [Ah] v.b.cac
>> Battery temperature [°C] v.b.temp
>> Inverter temperature [°C] v.i.temp (*)
>> Door open flag: Front Left v.d.fl (*)
>> Door open flag: Front Right v.d.fr (*)
>> Door open flag: Rear Left v.d.rl (*)
>> Door open flag: Rear Right v.d.rr (*)
>> Trunk open flag v.d.trunk (*)
>> Gear v.e.gear ms_v_env_gear
>> Drive pedal state [%] v.e.throttle (*)
>> Brake pedal state [%] v.e.footbrake (*)
>> Handbrake Set flag v.e.handbrake (*)
>> Car is Awake flag v.e.awake
>> Car cooling flag v.e.cooling (*)
>> Car heating flag v.e.heating (*)
>> Car HVAC is on flag v.e.hvac
>> Car is On flag v.e.on
>> Car is Locked flag v.e.locked (*)
>> Car headlights are on flag v.e.headlights (*)
>> Ambient temperature [°C] v.e.temp
>> Vehicle odometer [km] v.p.odometer
>> Tire Front Left pressure v.tp.fl.p (*)
>> Tire Front Right pressure v.tp.fr.p (*)
>> Tire Rear Right pressure v.tp.rr.p (*)
>> Tire Rear Left pressure v.tp.rl.p (*)
>>> Also, if any are unique or limited to
>>> one model vehicle or another, let me know that too. I'll update the
>>> table with the new information.
>> Currently, I'm not aware of any model-specific metrics, but hopefully
>> we will get feedback from others if there are any.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180429/c4a52281/attachment.html>
