[Ovmsdev] Lessons learnt, production batch #2 and onwards
Tue Apr 24 05:56:17 HKT 2018
Hi Mark,
We also need to handle home networks that are hidden.  I think both this
and the channel switch / scan problem can be handled by simply asking
the user to enter both the SSID and Passphrase manually.  It's not a
huge concern if it doesn't connect on restart, since the AP side still
works in AP+Client mode.  A connection failure can be highlighted for
re-entry (probably good regardless of whether you've completed the setup
procedure or not).
Greg
Mark Webb-Johnson wrote:
> Technically, my only concern is the switch from AP to AP+client mode
> and whether the existing wifi connection will die or survive the
> channel switch. We also have to do a wifi scan, in Access Point mode,
> but I think we can do that by just temporarily turning off access
> point or doing it before the access point is brought up.
