[Ovmsdev] Memory leak
Sun Apr 22 07:16:45 HKT 2018
On Sat, 21 Apr 2018, Michael Balzer wrote:
> the prompt is copied from the web shell. That's also the source of
> the "mo m" task, which is the execution task of the command.
Aha.
> I merged prop-cmdtask into master some weeks ago. I kept the branch
> for documentation, guess it can be removed now.
No worries.
> >> Nothing special to see. +14k on the events task vs. a fresh boot,
> >> but nothing that can explain the loss of more than 40k.
Here is my tally based on your command captures:
281968  100.00%  Total DRAM space
208816   74.06%  Total DRAM allocated
118368   41.98%  DRAM allocated by OVMS Events
 14600    5.18%  Free DRAM
 58552   20.77%  Overhead for 2927.6 blocks
So OVMS Events is using 42% of the total DRAM, or more than half of
what has been allocated.  I wonder if some of that could move to
SPIRAM?
I think your more than 40K missing is not a leak, it is the heap
overhead.  With heap poisoning enabled to allow the diagnostics, the
overhead on each block is 20 bytes.  Without heap poisoning the
overhead is one pointer, 4 bytes.  The 58K of overhead corresponds to
about 2900 allocated blocks.  There could well be that many, because
many of them are small.  Try a "mo m *" command which will dump the
details for individual blocks for all the tasks up to the buffer limit
of 1000 blocks.  Here are a coupl of sample sections of that output:
+ t=esp_timer s=  44 a=0x3ffca344  3F408AB4 3FFCA350 00000009 73626577 65767265 FEFE0072 FEFEFEFE 3FFCA384
+ t=esp_timer s=  12 a=0x3ffca384  4011B808 00000000 3FFB4288 BAAD5678 3FFCA3B4 ABBA1234 3FFAFAB0 0000000C
+ t=esp_timer s=  12 a=0x3ffca3a4  3FFCA164 3FFCA164 3FFCA344 BAAD5678 3FFCA3DC ABBA1234 3FFAFAB0 00000014
+ t=esp_timer s=  20 a=0x3ffca3c4  3F408F8C 3F405748 40127470 00000000 00000000 BAAD5678 3FFCA404 ABBA1234
+ t=esp_timer s=  20 a=0x3ffca3ec  3F411C30 3F411C38 40125D30 00000000 00000000 BAAD5678 3FFCA42C ABBA1234
+ t=esp_timer s=  20 a=0x3ffca414  3F411C44 3F411C4C 40125D30 00000000 00000000 BAAD5678 3FFCA448 ABBA1234
+ t=esp_timer s=   8 a=0x3ffca43c  3FFCA480 3FFCA414 BAAD5678 3FFCA470 ABBA1234 3FFAFAB0 00000014 3F411C58
+ t=esp_timer s=  20 a=0x3ffca458  3F411C58 3F411C60 40125D30 00000000 00000000 BAAD5678 3FFCA48C ABBA1234
+ t=esp_timer s=   8 a=0x3ffca480  3FFCA4C4 3FFCA458 BAAD5678 3FFCA4B4 ABBA1234 3FFAFAB0 00000014 3F411C6C
+ t=esp_timer s=  20 a=0x3ffca49c  3F411C6C 3F402EC8 40125D30 00000000 00000000 BAAD5678 3FFCA4D0 ABBA1234
+ t=OVMS Events s=  84 a=0x3ffcdd6c  3F4081F4 3F407000 3F441B9C 401276F8 3F465668 3FFCDD88 00000000 3FFD7E00
+ t=OVMS Events s=  24 a=0x3ffcddd4  00000000 3FFCDE68 00000000 00000000 3F407000 3FFCDD6C BAAD5678 3FFCDE58
+ t=OVMS Events s=  84 a=0x3ffcde00  3F4081F4 3F441B8C 3F441B9C 401276F8 3F465668 3FFCDE1C 00000000 3FFCDE00
+ t=OVMS Events s=  24 a=0x3ffcde68  00000001 3FFCDD40 3FFCDDD4 3FFCDEFC 3F441B8C 3FFCDE00 BAAD5678 3FFCDEEC
+ t=OVMS Events s=  84 a=0x3ffcde94  3F4081F4 3F442398 3F441BAC 4012764C 3F465668 3FFCDEB0 00000000 400E7A00
+ t=OVMS Events s=  24 a=0x3ffcdefc  00000000 3FFCDE68 00000000 00000000 3F442398 3FFCDE94 BAAD5678 3FFCDF50
+ t=OVMS Events s=  36 a=0x3ffcdf28  3F445990 3F40AEEC 00000001 00000017 00000013 00000012 FFFFFFFF FFFFFFFF
+ t=OVMS Events s=  24 a=0x3ffcdf60  00000000 3FFD943C 3FFDC810 3FFDA8C0 3F40AEEC 3FFCDF28 BAAD5678 3FFCDFE4
+ t=OVMS Events s=  84 a=0x3ffcdf8c  3F4081F4 3F40AEEC 3F441B9C 00000000 3F407BB8 3FFCDFA8 00000000 00000000
You see many of the blocks are 8, 12, 20, or 24 bytes, so the overhead
doubles the space used.  Some blocks are larger, so overall the
overhead is about 21% according to my tally.
The poisoning serves two purposes: it allows checks for buffer
overruns (8 bytes) in addition to tracking of task ownership and size
(8 bytes).  It might be feasible to drop the former while still
allowing the memory diagnostics to work.
> Am 21.04.2018 um 22:05 schrieb Stephen Casner:
> > Michael,
> > I don't have a quick explanation for the memory leak, but some aspects
> > of the sample output you show are curious.  The prompt "OVMS >"
> > predates Mark's change on 3/19 to remove the space but includes my
> > change on 3/20 that put the asterisk right after the task name like
> > "main*".  It also includes Mark's insertion of the "OVMS" prefix on
> > task names on 4/8 but not my fix to change the prompt to '#' for ssh
> > logins (assuming this was an ssh console).  Also I had never seen
> > tasks like "mo m".  Perhaps this was built in your local prop-cmdtask
> > branch or something?  In which case perhaps an update would fix the
> > memory leak?
> >                                                         -- Steve
> >> There seems to be a memory leak, after running the module over the past hours in my
> >> car, ssh couldn't allocate 4K for a new session and I had this status:
> >> OVMS > mo m
> >> Free 8-bit 14600/281968, 32-bit 8052/24308, SPIRAM 4129588/4194252
> >> --Task--     Total DRAM D/IRAM   IRAM SPIRAM   +/- DRAM D/IRAM   IRAM SPIRAM
> >> no task*           5348      0      0      0      +5348     +0     +0     +0
> >> main*             18084      0      0      0     +18084     +0     +0     +0
> >> esp_timer         39268      0    644  23436     +39268     +0   +644 +23436
> >> OVMS Events       53304  65064      0  10076     +53304 +65064     +0 +10076
> >> ipc0               7776      0      0      0      +7776     +0     +0     +0
> >> ipc1                 12      0      0      0        +12     +0     +0     +0
> >> tiT                 232    908      0   6376       +232   +908     +0  +6376
> >> OVMS SIMCOM           0   4512      0      0         +0  +4512     +0     +0
> >> wifi               1464     64      0   3512      +1464    +64     +0  +3512
> >> OVMS Console          0     20      0      0         +0    +20     +0     +0
> >> OVMS NetMan           0  12688      0     68         +0 +12688     +0    +68
> >> mo m                  0      0  15488  12000         +0     +0 +15488 +12000
> >> OVMS > mo t
> >> Number of Tasks = 20      Stack:  Now   Max Total    Heap 32-bit SPIRAM
> >> 3FFAFB48  1 Blk esp_timer         388   644  4096   39268    644  23436
> >> 3FFBDE54  2 Blk eventTask         448  1328  4608       0      0      0
> >> 3FFBFC50  3 Blk OVMS Events       444  3932  6144  118368      0  10076
> >> 3FFC4974  4 Blk OVMS CanRx        432   544  1024       0      0      0
> >> 3FFC9090  5 Blk ipc0              396   444  1024    7776      0      0
> >> 3FFC9690  6 Blk ipc1              396   444  1024      12      0      0
> >> 3FFCB4B8  9 Rdy IDLE              356   484  1024       0      0      0
> >> 3FFCBA4C 10 Rdy IDLE              360   488  1024       0      0      0
> >> 3FFCC7E0 11 Blk Tmr Svc           396  1820  3072       0      0      0
> >> 3FFC98FC 16 Blk tiT               496  2272  3072    1136      0   6576
> >> 3FFD7540 17 Blk OVMS SIMCOM       460  3020  4096    4512      0      0
> >> 3FFD951C 18 Blk wifi              424  2168  4096    1528      0   3512
> >> 3FFDBCB4 19 Blk pmT               416   576  2560       0      0      0
> >> 3FFDDABC 20 Blk OVMS Vehicle      456  2008  3072       0      0      0
> >> 3FFDFE38 21 Blk OVMS COrx         452   580  3072       0      0      0
> >> 3FFE1C88 22 Blk OVMS COwrk        532   532  1536       0      0      0
> >> 3FFE3E78 23 Blk OVMS Console      548  1716  6144      20      0      0
> >> 3FFE9430 24 Blk OVMS NetMan       732  5980  7168   12692      0     68
> >> 3FFEA9C8 25 Blk mdns              404  1724  4096       0      0      0
> >> 3FFFCD14 36 Rdy mo t              704  1936  5120      72      0      0
> >> Nothing special to see. +14k on the events task vs. a fresh boot, but nothing that can
> >> Odd, I'll watch this.
> >> Regards,
> >> Michael
