[Ovmsdev] Fwd: [openvehicles/Open-Vehicle-Monitoring-System-3] 29e333: Issue #36: Add support for ota/tag in config
Mon Apr 16 09:13:33 HKT 2018
A few changes to OTA this morning:
The ‘ota status’ command used to check available server version only if a WIFI network was up. It now does that if ANY network is up (including modem).
I’ve added a config instance ‘tag’ to parameter ‘ota’. This can be used to override the ota tag (default: main) at run-time.
I’ve added a config instance ‘server’ to parameter ‘ota’. This can be used to override the ota server URL (default: api.openvehicles.com/firmware/ota <http://api.openvehicles.com/firmware/ota>).
From now on, I’m going to be maintaining two tags for the production ota server api.openvehicles.com <http://api.openvehicles.com/>. These are:
main: for stable releases
edge: for bleeding edge developer releases
You can, for example, now set your module to bleeding-edge by ‘config set ota tag edge’.
> Begin forwarded message:
> From: GitHub <noreply at github.com>
> Subject: [openvehicles/Open-Vehicle-Monitoring-System-3] 29e333: Issue #36: Add support for ota/tag in config
> Date: 16 April 2018 at 8:37:46 AM HKT
> To: mark at webb-johnson.net
> Reply-To: GitHub <noreply at github.com>
> Branch: refs/heads/master
> Home: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3
> Commit: 29e33348f6dff949fd22567083de1d9db04b05e3
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/29e33348f6dff949fd22567083de1d9db04b05e3
> Author: Mark Webb-Johnson <mark at webb-johnson.net>
> Date: 2018-04-16 (Mon, 16 Apr 2018)
> Changed paths:
> M vehicle/OVMS.V3/components/ovms_ota/src/ovms_ota.cpp
> M vehicle/OVMS.V3/main/ovms_version.cpp
> Log Message:
> Issue #37: Add support for ota/server in config
> Issue #38: ota status should show available server version for modem as
> well as wifi
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180416/25496fe3/attachment.html>
