[Ovmsdev] It's Here!
Sat Apr 14 16:36:40 HKT 2018
Got mine as well, without customs hassle.
My dust caps were in place and OK. The top shell also is a bit wider than the bottom, but nowhere near 1 mm, more like 0.2 - 0.3.
Am 14.04.2018 um 00:49 schrieb Greg D.:
> Hi Mark,
> The 3.1 module arrived in today's mail.  I haven't plugged it in yet,
> but two "unboxing" observations...
> The unit looks really nice, though it seems that the top shell is a tad
> too wide and overlaps the bottom piece by nearly a mm on one corner.
> And, not evenly, at that; it's like the corner by the Vehicle connector
> got stretched a bit outward (or the other half pushed inward).  The
> other two sides are all pretty evenly matched.  The 3.0 proto unit was
> not like this.  {shrug}
> Also, the two SMA dust caps seemed to have had some reaction with the
> adhesive on the flap of the padded envelope.  They were stuck to the
> flap, pulled away from the connectors (so, not much dust protection),
> and the adhesive on the flap seemed to be very gooey in that area.  The
> caps seemed to have been more or less unaffected, so it's more of a
> cosmetic issue.  Perhaps they could point the module in the other
> direction (SMA end first), to prevent this in the future?
> My intent is to play "customer" with this unit, only using officially
> released code, updated through typical methods (i.e. not via the
> developer's kit) unless I need to do otherwise.  I've got some
> short-term distractions through the weekend, but will take it out for a
> spin next week.
> Greg
