[Ovmsdev] changes.txt
Thu Apr 12 14:06:42 HKT 2018
Taking into account Steve and Greg feedback, perhaps we need to define the criteria for what should be in there?
I think we need to focus on what is useful to the user. In particular things that we’ve done that may impact his usage experience.
I suggest a short one or two line summary headline. Then, individual points to cover:
User visible changes
Changes to functionality that could impact users
Enhancements and new features that would be of benefit to users
Github reported issues addressed
I am not sure about #4. Should we be reporting ALL github issues, or just those that meet the first three criteria?
Looking at the example, and what @Michael suggests removing, I think that would keep:
Wifi scan responsiveness
The “Server v2: 50 ms delay …” should probably be a github reported issue.
Watchdogs (included because it could impact users if they suddenly start to see random reboots, but I agree that this is borderline for inclusion)
I don’t think the SD CARD issue meets the above inclusion criteria. But, somebody who had been having issues with his SD CARD would probably be interested in knowing we have made changes to try to make it better.
Does that work?
> On 12 Apr 2018, at 12:13 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> I would reduce this much further to:
> ????-??-?? ??? ??????? OTA release
> - Tesla Model S: Support v.bat.soc, v.pos.speed and park/drive status metrics
> This is IMO the only change from the current log a normal user needs to know about.
> The SD card configuration is on the edge, I would remove that entry from the user info as well, as a normal user will (should) not need to touch these configs:
> - SD CARD: Provide configurable sdcard parameters:
> sdcard [maxfreq.khz] = 16000 Maximum frequency (in kHz) of SD CARD bus
> sdcard [automount] = yes Automatically mount SD CARD on insertion
> The DebugCrash records info is also on the edge, I would now also remove that from the changes file as no normal user can make use of that info:
> - Boot: store & send crash debug info (*-OVM-DebugCrash records)
> The remaining changes are bug fixes or internal stuff no user needs to know, only developers:
> - Wifi: Increase scan responsiveness (60 seconds -> 10, on first scan)
> - Server v2: Introduce a 50ms delay between setting charge mode and current in same command
> - Core: Changes to housekeeping and events tasks to move event delivery and housekeeping actions
> to the event task (removing housekeeping task)
> - Core: Enable watchdogs for production builds
> - SD CARD: Reliability improvements to SD CARD auto-mounting on insertion
> - Core: Introduce protection for thread safety while logging, to workaround ESP IDF bug
> https://github.com/espressif/esp-idf/issues/1837 <https://github.com/espressif/esp-idf/issues/1837>
> All this can be reduced to a single line "lots of bug fixes and optimizations".
> Am I too radical on this?
> Am 11.04.2018 um 02:06 schrieb Mark Webb-Johnson:
>> Yes, that is the intention. For v2, I generally did this for each firmware release by doing a ‘git lola’ (like your 'git log --oneline --no-merges’), going through the changelog, and updating the changes.txt with non technical translations of core functionality changes. Trivial changes were not recorded in changes.txt.
>> I just reviewed the latest, and this is what I came up with:
>> $ git log --oneline --no-merges 3.1.003 master
>> aeb7728 (HEAD -> master) Tesla Model S: Refinements for v.e.handbrake and Mph/Kph support
>> 52e8214 (origin/master, origin/HEAD) Web shell: touch keyboard optimization
>> 2eab5d3 Provide configurable parameters for sdcard: sdcard [maxfreq.khz] = 16000 sdcard [automount] = yes
>> a2804b8 Add ovms_utils.h for FormatHexDump.
>> 343ad45 Reimplement setting console prompt for secure mode
>> 09f6f6b Tesla Model S: Use 32bit arithmetic for data decoding
>> ed4d700 Tesla Model S: Use 32bit arithmetic for data decoding
>> 6f732b2 Improve hexdump of 're list' to show ascii printable characters.
>> 82cccc7 Tesla Model S: Gear selector - on/awake
>> 3e0d5b1 TeslaModelS: v.bat.soc and v.pos.speed metrics
>> e898c1b TeslaModelS: Fix for metric v.bat.soc
>> c5bc34a TeslaModelS: Fix for metric v.pos.speed
>> ad46fb2 Clone data passed to SignalEvent
>> ed32467 Default production config support for ESP IDF panic stub
>> b38b0ef Mutex protect fsync function call, on logging, to workaround ESP IDF bug https://github.com/espressif/esp-idf/issues/1837 <https://github.com/espressif/esp-idf/issues/1837>
>> 37c5f4b Boot: store & send crash debug info (*-OVM-DebugCrash records) Note: needs esp-idf update (daef4b5c11a646b7149bf3534e338f3070ae3abf)
>> 1bcbef9 Clone data passed to SignalEvent
>> d9931cb Changelog update
>> be39917 Run SD CARD automount in Events task context, not Timer.
>> f0969a3 Refactor housekeeping/events tasks to use Events task for signal dispatch and housekeeping.
>> 97775cf OVMS task naming cleanup
>> 90c00b8 Enable watchdog reset for production builds
>> fde6d8d OVMS task naming cleanup
>> f6a8de5 changes.txt update
>> 7ea18b4 Server v2: Delay 50ms on cmd #16 (between setting mode and current)
>> 21e4110 Increase wifi scan responsiveness
>> Becomes:
>> This process is helped if people can include full information in their commit messages - in particular for changes that impact features, usage, provide new options, etc - anything that is going to affect or be visible to the user.
>> Currently, the firmware download server has a file (http://api.openvehicles.com/firmware/ota/[v3.0|v3.1]/<tag>/ovms3.ver <http://api.openvehicles.com/firmware/ota/%5Bv3.0%7Cv3.1%5D/%3Ctag%3E/ovms3.ver>) that stores a one-line ‘current version’. I plan to change that to include the last few releases for changes.txt (as well as the version). That way, ‘ota status’ can show the changes in the latest version as well as the version number itself).
>>> On 11 Apr 2018, at 5:31 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> A suggestion for the changes.txt:
>>> I thought and now suggest this file is intended as an extract of high level changes, i.e. changes that extend or change the user interface and/or features of
>>> the system, but not bug fixes or internal reworks.
>>> A log of all changes can be created automatically from the git log, no need to do that manually.
>>> git log --oneline --no-merges 3.1.000..
>>> If we add all commits, users will stop reading this file. If we reduce it to high level entries, it becomes a valuable info for users.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180412/c491aa84/attachment-0001.html>
