[Ovmsdev] changes.txt
Thu Apr 12 00:13:41 HKT 2018
Mark,
I would reduce this much further to:
????-??-?? ??? ??????? OTA release
- Tesla Model S: Support v.bat.soc, v.pos.speed and park/drive status metrics
This is IMO the only change from the current log a normal user needs to know about.
The SD card configuration is on the edge, I would remove that entry from the user info as well, as a normal user will (should) not need to touch these configs:
- SD CARD: Provide configurable sdcard parameters:
sdcard [maxfreq.khz] = 16000 Maximum frequency (in kHz) of SD CARD bus
sdcard [automount] = yes Automatically mount SD CARD on insertion
The DebugCrash records info is also on the edge, I would now also remove that from the changes file as no normal user can make use of that info:
- Boot: store & send crash debug info (*-OVM-DebugCrash records)
The remaining changes are bug fixes or internal stuff no user needs to know, only developers:
- Wifi: Increase scan responsiveness (60 seconds -> 10, on first scan)
- Server v2: Introduce a 50ms delay between setting charge mode and current in same command
- Core: Changes to housekeeping and events tasks to move event delivery and housekeeping actions
to the event task (removing housekeeping task)
- Core: Enable watchdogs for production builds
- SD CARD: Reliability improvements to SD CARD auto-mounting on insertion
- Core: Introduce protection for thread safety while logging, to workaround ESP IDF bug
https://github.com/espressif/esp-idf/issues/1837
All this can be reduced to a single line "lots of bug fixes and optimizations".
Am I too radical on this?
Am 11.04.2018 um 02:06 schrieb Mark Webb-Johnson:
> Yes, that is the intention. For v2, I generally did this for each firmware release by doing a ‘git lola’ (like your 'git log --oneline --no-merges’), going
> through the changelog, and updating the changes.txt with non technical translations of core functionality changes. Trivial changes were not recorded in
> changes.txt.
> I just reviewed the latest, and this is what I came up with:
> $ git log --oneline --no-merges 3.1.003 master
> aeb7728 (HEAD -> master) Tesla Model S: Refinements for v.e.handbrake and Mph/Kph support
> 52e8214 (origin/master, origin/HEAD) Web shell: touch keyboard optimization
> 2eab5d3 Provide configurable parameters for sdcard: sdcard [maxfreq.khz] = 16000 sdcard [automount] = yes
> a2804b8 Add ovms_utils.h for FormatHexDump.
> 343ad45 Reimplement setting console prompt for secure mode
> 09f6f6b Tesla Model S: Use 32bit arithmetic for data decoding
> ed4d700 Tesla Model S: Use 32bit arithmetic for data decoding
> 6f732b2 Improve hexdump of 're list' to show ascii printable characters.
> 82cccc7 Tesla Model S: Gear selector - on/awake
> 3e0d5b1 TeslaModelS: v.bat.soc and v.pos.speed metrics
> e898c1b TeslaModelS: Fix for metric v.bat.soc
> c5bc34a TeslaModelS: Fix for metric v.pos.speed
> ad46fb2 Clone data passed to SignalEvent
> ed32467 Default production config support for ESP IDF panic stub
> b38b0ef Mutex protect fsync function call, on logging, to workaround ESP IDF bug https://github.com/espressif/esp-idf/issues/1837
> 37c5f4b Boot: store & send crash debug info (*-OVM-DebugCrash records) Note: needs esp-idf update (daef4b5c11a646b7149bf3534e338f3070ae3abf)
> 1bcbef9 Clone data passed to SignalEvent
> d9931cb Changelog update
> be39917 Run SD CARD automount in Events task context, not Timer.
> f0969a3 Refactor housekeeping/events tasks to use Events task for signal dispatch and housekeeping.
> 97775cf OVMS task naming cleanup
> 90c00b8 Enable watchdog reset for production builds
> fde6d8d OVMS task naming cleanup
> f6a8de5 changes.txt update
> 7ea18b4 Server v2: Delay 50ms on cmd #16 (between setting mode and current)
> 21e4110 Increase wifi scan responsiveness
> Becomes:
> This process is helped if people can include full information in their commit messages - in particular for changes that impact features, usage, provide new
> options, etc - anything that is going to affect or be visible to the user.
> Currently, the firmware download server has a file (http://api.openvehicles.com/firmware/ota/[v3.0|v3.1]/<tag>/ovms3.ver
> <http://api.openvehicles.com/firmware/ota/%5Bv3.0%7Cv3.1%5D/%3Ctag%3E/ovms3.ver>) that stores a one-line ‘current version’. I plan to change that to include
> the last few releases for changes.txt (as well as the version). That way, ‘ota status’ can show the changes in the latest version as well as the version
> number itself).
>> On 11 Apr 2018, at 5:31 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> A suggestion for the changes.txt:
>> I thought and now suggest this file is intended as an extract of high level changes, i.e. changes that extend or change the user interface and/or features of
>> the system, but not bug fixes or internal reworks.
>> A log of all changes can be created automatically from the git log, no need to do that manually.
>> git log --oneline --no-merges 3.1.000..
>> If we add all commits, users will stop reading this file. If we reduce it to high level entries, it becomes a valuable info for users.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180411/d11bb176/attachment-0001.html>
