[Ovmsdev] changes.txt
Wed Apr 11 08:06:20 HKT 2018
Yes, that is the intention. For v2, I generally did this for each firmware release by doing a ‘git lola’ (like your 'git log --oneline --no-merges’), going through the changelog, and updating the changes.txt with non technical translations of core functionality changes. Trivial changes were not recorded in changes.txt.
I just reviewed the latest, and this is what I came up with:
$ git log --oneline --no-merges 3.1.003 master
aeb7728 (HEAD -> master) Tesla Model S: Refinements for v.e.handbrake and Mph/Kph support
52e8214 (origin/master, origin/HEAD) Web shell: touch keyboard optimization
2eab5d3 Provide configurable parameters for sdcard: sdcard [maxfreq.khz] = 16000 sdcard [automount] = yes
a2804b8 Add ovms_utils.h for FormatHexDump.
343ad45 Reimplement setting console prompt for secure mode
09f6f6b Tesla Model S: Use 32bit arithmetic for data decoding
ed4d700 Tesla Model S: Use 32bit arithmetic for data decoding
6f732b2 Improve hexdump of 're list' to show ascii printable characters.
82cccc7 Tesla Model S: Gear selector - on/awake
3e0d5b1 TeslaModelS: v.bat.soc and v.pos.speed metrics
e898c1b TeslaModelS: Fix for metric v.bat.soc
c5bc34a TeslaModelS: Fix for metric v.pos.speed
ad46fb2 Clone data passed to SignalEvent
ed32467 Default production config support for ESP IDF panic stub
b38b0ef Mutex protect fsync function call, on logging, to workaround ESP IDF bug https://github.com/espressif/esp-idf/issues/1837
37c5f4b Boot: store & send crash debug info (*-OVM-DebugCrash records) Note: needs esp-idf update (daef4b5c11a646b7149bf3534e338f3070ae3abf)
1bcbef9 Clone data passed to SignalEvent
d9931cb Changelog update
be39917 Run SD CARD automount in Events task context, not Timer.
f0969a3 Refactor housekeeping/events tasks to use Events task for signal dispatch and housekeeping.
97775cf OVMS task naming cleanup
90c00b8 Enable watchdog reset for production builds
fde6d8d OVMS task naming cleanup
f6a8de5 changes.txt update
7ea18b4 Server v2: Delay 50ms on cmd #16 (between setting mode and current)
21e4110 Increase wifi scan responsiveness
Becomes:
????-??-?? ??? ??????? OTA release
- Wifi: Increase scan responsiveness (60 seconds -> 10, on first scan)
- Server v2: Introduce a 50ms delay between setting charge mode and current in same command
- Core: Changes to housekeeping and events tasks to move event delivery and housekeeping actions
to the event task (removing housekeeping task)
- Core: Enable watchdogs for production builds
- SD CARD: Reliability improvements to SD CARD auto-mounting on insertion
- SD CARD: Provide configurable sdcard parameters:
sdcard [maxfreq.khz] = 16000 Maximum frequency (in kHz) of SD CARD bus
sdcard [automount] = yes Automatically mount SD CARD on insertion
- Boot: store & send crash debug info (*-OVM-DebugCrash records)
- Core: Introduce protection for thread safety while logging, to workaround ESP IDF bug
- Tesla Model S: Support v.bat.soc, v.pos.speed and park/drive status metrics
This process is helped if people can include full information in their commit messages - in particular for changes that impact features, usage, provide new options, etc - anything that is going to affect or be visible to the user.
Currently, the firmware download server has a file (http://api.openvehicles.com/firmware/ota/[v3.0|v3.1]/<tag>/ovms3.ver <http://api.openvehicles.com/firmware/ota/%5Bv3.0%7Cv3.1%5D/%3Ctag%3E/ovms3.ver>) that stores a one-line ‘current version’. I plan to change that to include the last few releases for changes.txt (as well as the version). That way, ‘ota status’ can show the changes in the latest version as well as the version number itself).
> On 11 Apr 2018, at 5:31 AM, Michael Balzer <dexter at expeedo.de> wrote:
> A suggestion for the changes.txt:
> I thought and now suggest this file is intended as an extract of high level changes, i.e. changes that extend or change the user interface and/or features of
> the system, but not bug fixes or internal reworks.
> A log of all changes can be created automatically from the git log, no need to do that manually.
> git log --oneline --no-merges 3.1.000..
> If we add all commits, users will stop reading this file. If we reduce it to high level entries, it becomes a valuable info for users.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180411/ee94431a/attachment-0001.html>
