[Ovmsdev] Crash debugging
    Stephen Casner
    casner at acm.org
    Wed Apr 11 02:35:06 HKT 2018
Michael,
That's very interesting.  That possible cause had not occurred to me
because I don't use EditorConfig.  I looked into it briefly a while
back, but didn't explore what is necessary to use it with Emacs.
In the past I have used Emacs' own mechanism, which puts the settings
in comments at the top of the file being edited, but I don't have the
freedom to do that in this project so I manually set a profile each
time I open a file.  That is tolerable because I rarely reboot my Mac
and I leave Emacs running.  But it might be worthwhile to consider
using .editorconfig in our project.
On Mon, 9 Apr 2018, Michael Balzer wrote:
> Mystery solved: there is a .editorconfig file in the esp-idf root directory which my editor (kate) automatically uses, sadly without telling me or showing in
> the config menu.
> Obviously, the last one who worked on the two files affected used an editor that doesn't use that scheme.
> Am 09.04.2018 um 04:23 schrieb Mark Webb-Johnson:
> > I use Atom, which ships by default with the 'whitespace' package. That removes trailing whitespaces.
> > Did a quick check in our project, and we have it in 10 files in main/ - mostly whitespace on blank lines (which my editor is set to NOT remove - but I think it should).
> > In our own project, I think we should in general remove this. But, as Steven says, better to do it as a separate commit. Mea culpa.
> > Regards, Mark.
> >> On 9 Apr 2018, at 1:20 AM, Michael Balzer <dexter at expeedo.de> wrote:
> >> Stephen,
> >> I don't care about trailing whitespace, but I know what you mean. I usually set my diff options to "-b" and "core.whitespace" to "-trailing-space" so git also
> >> doesn't care.
> >> My editor is set to "do not remove trailing whitespace", but you're right, somehow the trailing ws in Kconfig and xtensa_api.h have been removed. Strange, I
> >> can't explain that... maybe a git feature I don't know about?
> >> Regards,
> >> Michael
> >> Am 08.04.2018 um 18:35 schrieb Stephen Casner:
> >>> Michael,
> >>> I just took a quick look at the diff.  There are many lines changed
> >>> because trailing whitespace was removed, presumably as an automatic
> >>> action by your editor.  Is that something you can configure it not to
> >>> do?
> >>> I noticed the same phenomenon on some of Mark's recent commits as well,
> >>> when the files being committed were ones that he had created/edited
> >>> before, so perhaps you and he are using a new editor or its policy has
> >>> changed.
> >>> I don't like trailing whitespace, and I am careful to avoid it as I
> >>> write code.  However, I also take extra effort to avoid removing any
> >>> existing trailing whitespace (or make other unrelated changes like
> >>> comment fixes) as part of committing a change, especially for source
> >>> that isn't mine.  I sometimes make separate commits with just those
> >>> nonfunctional changes.  This is to keep the annotation log meaningful.
> >>> I don't mean this as a major criticism, just a question.
> >>>                                                        -- Steve
> >>> _______________________________________________
> >>> OvmsDev mailing list
> >>> OvmsDev at lists.openvehicles.com
> >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
> >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
