[Ovmsdev] Commit 6f732b2 issue without CONFIG_OVMS_COMP_OBD2ECU
Tue Apr 10 17:59:14 HKT 2018
Julian,
Sorry about that. Should be fixed now.
> On 10 Apr 2018, at 5:22 PM, Julien “JaXX” Banchet <jaxx at jaxx.org> wrote:
> Hi,
> Just a heads up, seems commit 6f732b2 doesn’t like missing CONFIG_OVMS_COMP_OBD2ECU
> CXX build/pcp/pcp.o
> AR build/pcp/libpcp.a
> CC build/pthread/pthread.o
> CC build/pthread/pthread_cond_var.o
> CC build/pthread/pthread_local_storage.o
> AR build/pthread/libpthread.a
> CXX build/retools/src/retools.o
> /Users/jaxx/Projects/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/retools/src/retools.cpp: In function 'void re_list(int, OvmsWriter*, OvmsCommand*, int, const char* const*)':
> /Users/jaxx/Projects/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/retools/src/retools.cpp:260:91: error: 'FormatHexDump' was not declared in this scope
> FormatHexDump(&s, (const char*)it->second->last.data.u8, it->second->last.FIR.B.DLC, 8);
> make[1]: *** [/Users/jaxx/Projects/esp-idf/make/component_wrapper.mk:274: src/retools.o] Error 1
> make: *** [/Users/jaxx/Projects/esp-idf/make/project.mk:450: component-retools-build] Error 2
> With CONFIG_OVMS_COMP_OBD2ECU=y it compiles fine.
> JB./.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180410/fa8c6913/attachment.html>
