[Ovmsdev] Crash debugging
Mon Apr 9 10:23:01 HKT 2018
I use Atom, which ships by default with the ‘whitespace’ package. That removes trailing whitespaces.
Did a quick check in our project, and we have it in 10 files in main/ - mostly whitespace on blank lines (which my editor is set to NOT remove - but I think it should).
In our own project, I think we should in general remove this. But, as Steven says, better to do it as a separate commit. Mea culpa.
> On 9 Apr 2018, at 1:20 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Stephen,
> I don't care about trailing whitespace, but I know what you mean. I usually set my diff options to "-b" and "core.whitespace" to "-trailing-space" so git also
> doesn't care.
> My editor is set to "do not remove trailing whitespace", but you're right, somehow the trailing ws in Kconfig and xtensa_api.h have been removed. Strange, I
> can't explain that… maybe a git feature I don't know about?
> Am 08.04.2018 um 18:35 schrieb Stephen Casner:
>> Michael,
>> I just took a quick look at the diff.  There are many lines changed
>> because trailing whitespace was removed, presumably as an automatic
>> action by your editor.  Is that something you can configure it not to
>> do?
>> I noticed the same phenomenon on some of Mark's recent commits as well,
>> when the files being committed were ones that he had created/edited
>> before, so perhaps you and he are using a new editor or its policy has
>> changed.
>> I don't like trailing whitespace, and I am careful to avoid it as I
>> write code.  However, I also take extra effort to avoid removing any
>> existing trailing whitespace (or make other unrelated changes like
>> comment fixes) as part of committing a change, especially for source
>> that isn't mine.  I sometimes make separate commits with just those
>> nonfunctional changes.  This is to keep the annotation log meaningful.
>> I don't mean this as a major criticism, just a question.
>>                                                        -- Steve
