[Ovmsdev] V3 Renault Twizy 0.1.0
    Sun Oct 29 18:37:58 HKT 2017
…just pushed.
I've also made some minor changes & extensions to the framework,
hopefully helpful.
This is very basic support (~10%). It covers CAN processing and battery
/ power monitoring. Just metrics output for now, no commands or
notifications.
Free RAM is down to 36.6 K after loading the module.
I've removed the "v." from the "x.rt.v." metrics names, as nearly all
"x.rt" metrics are (of course) vehicle metrics. "x.rt.m.version" does
not fit the scheme and breaks into the "motor" namespace, as "m." was in
use before, maybe we should better use "mot." for motor metrics.
OVMS > config list x.rt
x.rt
  autopower: yes
  autoreset: yes
  canwrite: no
  cap_act_prc: 87.4
  cap_nom_ah: 108.0
  chargelevel: 0
  chargemode: 0
  console: no
  kickdown: yes
  maxrange: 71
  suffrange: 65
  suffsoc: 85
OVMS > metrics list
m.freeram                                36644
m.hardware                               OVMS WIFI BLE BT cores=2
rev=ESP32/1
m.monotonic                              541Sec
m.net.mdm.iccid
m.net.mdm.model
m.net.provider                           WLAN-214677
m.net.sq
m.net.type                               wifi
m.serial                                 30:ae:a4:37:25:88
m.tasks                                  17
m.time.utc                               546Sec
m.version                                3.0.0/factory/main build (idf
v2.1-20-g88ab5d48) Oct 29 2017 09:15:17
s.v2.connected
s.v2.peers
v.b.12v.current                          1.6A
v.b.12v.voltage                          0.527473V
v.b.cac                                  94.392Ah
v.b.current                              -36A
v.b.energy.recd                          0.000739342kWh
v.b.energy.used                          0kWh
v.b.power                                -2.0224kW
v.b.range.est                            50Km
v.b.range.full                           68.2571Km
v.b.range.ideal                          49Km
v.b.soc                                  71.92%
v.b.soh                                  100%
v.b.temp                                 15.4286°C
v.b.voltage                              56.2V
v.c.charging                             yes
v.c.climit
v.c.current                              36A
v.c.duration.full                        82Min
v.c.duration.range                       50Min
v.c.duration.soc                         25Min
v.c.kwh                                  0.000739342kWh
v.c.minutes                              6Min
v.c.mode                                 standard
v.c.pilot                                yes
v.c.state                                charging
v.c.substate                             go
v.c.temp                                 25°C
v.c.timermode
v.c.timerstart
v.c.type
v.c.voltage                              230V
v.d.cp                                   yes
v.d.fl
v.d.fr
v.d.hood
v.d.rl
v.d.rr
v.d.trunk
v.e.alarm
v.e.awake                                no
v.e.c.config                             no
v.e.c.login                              no
v.e.charging12v                          yes
v.e.cooling
v.e.drivemode
v.e.handbrake
v.e.headlights
v.e.heating
v.e.hvac
v.e.locked                               no
v.e.on                                   no
v.e.parktime
v.e.temp
v.e.valet                                no
v.i.temp
v.m.temp                                 0°C
v.p.altitude
v.p.direction
v.p.gpslock
v.p.latitude
v.p.longitude
v.p.odometer                             3456.51Km
v.p.satcount
v.p.speed                                0Kph
v.p.trip                                 3456.51Km
v.tp.fl.p
v.tp.fl.t
v.tp.fr.p
v.tp.fr.t
v.tp.rl.p
v.tp.rl.t
v.tp.rr.p
v.tp.rr.t
v.type                                   RT
v.vin                                    7378280
x.rt.b.cell.01.voltage.act               4.025V
x.rt.b.cell.01.voltage.max               4.025V
x.rt.b.cell.01.voltage.maxdev            2.85712V
x.rt.b.cell.01.voltage.min               4.02V
x.rt.b.cell.02.voltage.act               4.015V
x.rt.b.cell.02.voltage.max               4.015V
x.rt.b.cell.02.voltage.maxdev            0.857117V
x.rt.b.cell.02.voltage.min               4.01V
x.rt.b.cell.03.voltage.act               4.015V
x.rt.b.cell.03.voltage.max               4.015V
x.rt.b.cell.03.voltage.maxdev            0.857117V
x.rt.b.cell.03.voltage.min               4.01V
x.rt.b.cell.04.voltage.act               4.01V
x.rt.b.cell.04.voltage.max               4.015V
x.rt.b.cell.04.voltage.maxdev            0.857117V
x.rt.b.cell.04.voltage.min               4.005V
x.rt.b.cell.05.voltage.act               4.015V
x.rt.b.cell.05.voltage.max               4.015V
x.rt.b.cell.05.voltage.maxdev            0.857117V
x.rt.b.cell.05.voltage.min               4.01V
x.rt.b.cell.06.voltage.act               4.015V
x.rt.b.cell.06.voltage.max               4.015V
x.rt.b.cell.06.voltage.maxdev            -1.14288V
x.rt.b.cell.06.voltage.min               4.005V
x.rt.b.cell.07.voltage.act               4.015V
x.rt.b.cell.07.voltage.max               4.015V
x.rt.b.cell.07.voltage.maxdev            0.285706V
x.rt.b.cell.07.voltage.min               4.01V
x.rt.b.cell.08.voltage.act               4.01V
x.rt.b.cell.08.voltage.max               4.01V
x.rt.b.cell.08.voltage.maxdev            -1.14288V
x.rt.b.cell.08.voltage.min               4.005V
x.rt.b.cell.09.voltage.act               4.01V
x.rt.b.cell.09.voltage.max               4.01V
x.rt.b.cell.09.voltage.maxdev            -1.14288V
x.rt.b.cell.09.voltage.min               4.005V
x.rt.b.cell.10.voltage.act               4.01V
x.rt.b.cell.10.voltage.max               4.01V
x.rt.b.cell.10.voltage.maxdev            -1.14288V
x.rt.b.cell.10.voltage.min               4.005V
x.rt.b.cell.11.voltage.act               4.015V
x.rt.b.cell.11.voltage.max               4.015V
x.rt.b.cell.11.voltage.maxdev            0.285706V
x.rt.b.cell.11.voltage.min               4.01V
x.rt.b.cell.12.voltage.act               4.01V
x.rt.b.cell.12.voltage.max               4.01V
x.rt.b.cell.12.voltage.maxdev            -1.14288V
x.rt.b.cell.12.voltage.min               4.005V
x.rt.b.cell.13.voltage.act               4.01V
x.rt.b.cell.13.voltage.max               4.01V
x.rt.b.cell.13.voltage.maxdev            -1.14288V
x.rt.b.cell.13.voltage.min               4.005V
x.rt.b.cell.14.voltage.act               4.025V
x.rt.b.cell.14.voltage.max               4.025V
x.rt.b.cell.14.voltage.maxdev            2.14288V
x.rt.b.cell.14.voltage.min               4.015V
x.rt.b.cell.15.voltage.act               0V
x.rt.b.cell.15.voltage.max               0V
x.rt.b.cell.15.voltage.maxdev            0V
x.rt.b.cell.15.voltage.min               0V
x.rt.b.cell.16.voltage.act               0V
x.rt.b.cell.16.voltage.max               0V
x.rt.b.cell.16.voltage.maxdev            0V
x.rt.b.cell.16.voltage.min               0V
x.rt.b.cell.cnt                          14
x.rt.b.cmod.01.temp.act                  16°C
x.rt.b.cmod.01.temp.max                  16°C
x.rt.b.cmod.01.temp.maxdev               0.57143°C
x.rt.b.cmod.01.temp.min                  16°C
x.rt.b.cmod.02.temp.act                  15°C
x.rt.b.cmod.02.temp.max                  15°C
x.rt.b.cmod.02.temp.maxdev               -0.42857°C
x.rt.b.cmod.02.temp.min                  15°C
x.rt.b.cmod.03.temp.act                  16°C
x.rt.b.cmod.03.temp.max                  16°C
x.rt.b.cmod.03.temp.maxdev               0.57143°C
x.rt.b.cmod.03.temp.min                  16°C
x.rt.b.cmod.04.temp.act                  15°C
x.rt.b.cmod.04.temp.max                  15°C
x.rt.b.cmod.04.temp.maxdev               -0.42857°C
x.rt.b.cmod.04.temp.min                  15°C
x.rt.b.cmod.05.temp.act                  16°C
x.rt.b.cmod.05.temp.max                  16°C
x.rt.b.cmod.05.temp.maxdev               0.57143°C
x.rt.b.cmod.05.temp.min                  16°C
x.rt.b.cmod.06.temp.act                  15°C
x.rt.b.cmod.06.temp.max                  15°C
x.rt.b.cmod.06.temp.maxdev               -0.42857°C
x.rt.b.cmod.06.temp.min                  15°C
x.rt.b.cmod.07.temp.act                  15°C
x.rt.b.cmod.07.temp.max                  15°C
x.rt.b.cmod.07.temp.maxdev               -0.42857°C
x.rt.b.cmod.07.temp.min                  15°C
x.rt.b.cmod.08.temp.act                  -40°C
x.rt.b.cmod.08.temp.max                  -40°C
x.rt.b.cmod.08.temp.maxdev               0°C
x.rt.b.cmod.08.temp.min                  -40°C
x.rt.b.cmod.cnt                          7
x.rt.b.pack.1.temp.stddev.max            0.495093°C
x.rt.b.pack.1.voltage.max                56.2V
x.rt.b.pack.1.voltage.min                56.1V
x.rt.b.pack.1.voltage.stddev.max         0.00586302V
x.rt.b.pack.cnt                          1
x.rt.m.version                           0.1.0 Oct 29 2017 10:44:20
x.rt.p.stats.acc.dist                    0Km
x.rt.p.stats.acc.recd                    0kWh
x.rt.p.stats.acc.spdavg                  0Kph/s
x.rt.p.stats.acc.used                    0kWh
x.rt.p.stats.cst.dist                    0Km
x.rt.p.stats.cst.recd                    0.000739342kWh
x.rt.p.stats.cst.spdavg                  0Kph
x.rt.p.stats.cst.used                    0kWh
x.rt.p.stats.dec.dist                    0Km
x.rt.p.stats.dec.recd                    0kWh
x.rt.p.stats.dec.spdavg                  0Kph/s
x.rt.p.stats.dec.used                    0kWh
x.rt.p.stats.ldn.dist                    0Km
x.rt.p.stats.ldn.hsum                    0m
x.rt.p.stats.ldn.recd                    0kWh
x.rt.p.stats.ldn.used                    0kWh
x.rt.p.stats.lup.dist                    0Km
x.rt.p.stats.lup.hsum                    0m
x.rt.p.stats.lup.recd                    0kWh
x.rt.p.stats.lup.used                    0kWh
