[Ovmsdev] V3 progress
Tom Parker
tom at carrott.org
Mon Oct 23 09:19:13 HKT 2017
Hi Geir,
I see you've got Soule on line 41, and you've used the NL vehicle code
on line 63 of vehicle_kiasoulev.cpp.
Otherwise it looks good.
I've been porting the Leaf v2 logic with as few changes as possible. The
changes are mostly simple, replacement of can_databuffer with d and
replacing the global state variables with metrics setters. I can still
make sense of a diff between the v3 .cpp file and the v2 .c file. Once I
have full feature parity between v2 and v3, I'll probably refactor the
cpp code some.
On 23/10/17 09:50, Geir Øyvind Vælidalo wrote:
> Mark,
> I just sent a Pull request for the initial Kia Soul EV-stub.
> I’m still a newbie on GIT so forgive me if I make a mess! Most of the
> time spent so far is setting up esp-idf and trying to figure out GIT
> again 🙂
> Geir
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171023/45f239be/attachment.htm>
