[Ovmsdev] Enable/disable mode, and secure commands
Sat Oct 14 21:25:26 HKT 2017
We’ve implemented the ‘enable’ and ‘disable’ commands, and corresponding secure module for the consoles.
The module password is in:
Config
Param: password
Instance: module
Value: <plaintextpassword>
If there is no password defined (default case), you can just type ‘enable’ without password, and you’ll get into enable mode. Everything will be as it was before.
If a module password has been set, then you must type ‘enable <password>’ and the password must match, to enter enable mode. If the password you enter is wrong, then there will be a five second delay before you can try again (to limit brute force attacks).
The ‘disable’ command will switch back to insecure mode (the default), and some (most) commands will be restricted.
If there is no password/module defined, then the consoles will default to secure (enable) mode.
For example:
OVMS > vfs ls /store
Error: Secure command requires 'enable' mode
OVMS > enable <password>
Secure mode
ovms_config
events
OVMS > disable
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171014/9ceeb6b9/attachment.htm>
