[Ovmsdev] V3 progress
Tom Parker
tom at carrott.org
Wed Oct 11 03:17:02 HKT 2017
On 10/10/17 23:39, Tom Parker wrote:
> I'll test the vfs append tomorrow too
I think there is a problem with the simcom support. The following trace
at the bottom of this mail happens on startup and it reboots before
doing it again in a loop. I haven't startup tasks. I've got the
hologram simcard in it but haven't registered it or anything like that,
so maybe an error is being reported that isn't being handled. I turned
off the simcom support in make menuconfig and it's stable.
The vfs things don't work:
OVMS > vfs mkdir /store/scripts
Error: Could not create VFS directory
It also used to store my config across power cycles but it doesn't do
that anymore.
Is this relevant:
I (1132) ovms_main: Mounting CONFIG...
E (1132) vfs_fat_spiflash: Failed to find FATFS partition (type='data',
subtype='fat', partition_label='store'). Check the partition table.
Initialising OVMS CONFIG within STORE
I appear to be using the ./vehicle/OVMS.V3/partitions.csv partition
table, does /store need formatting? I see there is autoformat code in
the sdcard paths, but not in the internal storage?
Simcom reboot loop referred to above:
I (2280) simcom: State: Enter CheckPowerOff state
SIMCOM tx 41 54 0d 0a AT.. ***ERROR*** A stack overflow in
task Tmr Svc has been detected.
abort() was called at PC 0x400887b8 on core 0
0x400887b8: vApplicationStackOverflowHook at
/home/ubuntu/esp/esp-idf/components/esp32/./panic.c:519
Backtrace: 0x400886a0:0x3ffc7670 0x4008879f:0x3ffc7690
0x400887b8:0x3ffc76b0 0x400864e9:0x3ffc76d0 0x40087a9c:0x3ffc76f0
0x40087a56:0xa5a5a5a5
0x400886a0: invoke_abort at
0x4008879f: abort at /home/ubuntu/esp/esp-idf/components/esp32/./panic.c:519
0x400864e9: vTaskSwitchContext at
/home/ubuntu/esp/esp-idf/components/freertos/./tasks.c:4446
0x40087a9c: _frxt_dispatch at ??:?
0x40087a56: _frxt_int_exit at ??:?
