[Ovmsdev] En route...
Tue Oct 10 11:19:37 HKT 2017
Finally, the European ones are arriving. Two weeks.
I made some progress with the SIMCOM last night. Got basic level 1 power control working, along with initialisation and modem model/iccid identification. Structure of the state machine looks good. Incoming SMS messages even display on the diagnostic trace, which is progress… There is quite a bit of diagnostic logging going out at the moment, which I will remove once things are stable.
Next is the tricky bit - SIMCOM CMUX support for a channel multiplexor.
> On 10 Oct 2017, at 3:22 AM, Geir Øyvind Vælidalo <geir at validalo.net> wrote:
> Got the package today :-D
> Are going on vacation tomorrow though, so no time to play yet. Will try to read up while traveling.
> Thanks, Mark!
> Geir
>> 20. sep. 2017 kl. 03:54 skrev Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>:
>> <PastedGraphic-1.tiff>
>> The first 10 developer modules (and modems, and 3D printed cases) are on the way to me. China->HK SF-Express is pretty amazing, so I should get them tomorrow morning.
>> We’ve identified 10 worthy developers, so I’ll turn these around and get them out to you guys as soon as I can.
>> In other news, I’ve started work on the documentation. Mostly a placeholder at the moment, but I’ll expand on it over the next few days so at least the developers getting these modules should have *some* documentation to get them started. V3 documentation is in Google Docs, and the following links will allow you to view and comment:
>> OVMS v3 Developer Guide <https://docs.google.com/document/d/1q5M9Lb5jzQhJzPMnkMKwy4Es5YK12ACQejX_NWEixr0/edit?usp=sharing>
>> OVMS v3 User Guide <https://docs.google.com/document/d/16JrXR7rybp-18DrEoeh1rg6GqQT_jVBvhaXh2oEWRHw/edit?usp=sharing>
>> Regards, Mark
>> <PastedGraphic-5.tiff>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171010/0f0615a4/attachment.htm>
