[Ovmsdev] RAM
Wed Oct 25 13:09:39 HKT 2017
I'd like to add another $.02 regarding RAM usage.  We need to consider
the impact of all three modes of RAM usage:
1. static declaration of variables
2. local (automatic) variables that cause the maximum stack usage to
increase so we need to dedicate a larger stack allocation
3. dynamic allocations from the heap
I have more specific comments for each of these.
1.  If you need a large buffer, declaring it as static storage means
that it is always allocated even if your code is not being used
(unless it is something like vehicle-specific code that is configured
out).  So, it would be better to dynamically allocate that buffer
space from the heap (malloc) when needed and then free it when
finished so that the usage is only temporary.  That way the same space
might be used for other purposes at other times.
2.  I recomment NOT USING std::string except where it is really needed
and useful.  In particular if you have a function parameter that is
always supplied as a character constant but the type of the parameter
is std::string then the compiler needs to expand the caller's stack
space by 32 bytes, for each such instance of the call, to hold the
std:string structure.  Additional heap space is required for the
characters.  None of that would be required if the parameter type were
const char*.  The same problem applies to functions that return
std::string, since the compiler must allocate stack space in the
calling function for the return value to be copied.  In particular if
the caller is just going to print that string with .c_str(), it would
be much better to put the .c_str() in the called function and return
the const char* UNDER ONE IMPORTANT CONDITION: this depends on the
std::string in the called function being stable, such as a member
variable of the class.  If the string in the called function is
automatic (allocated on the stack), then the .c_str() of it won't be
valid in the caller.
I saved substantial stack space and also heap space by changing the
command maps in OvmsCommand from map<std::string, OvmsCommand*> to
map<const char*, OvmsCommand*, CompareCharPtr>.  This was possible
because all of the command token strings that are put in the map come
from character constants anyway, and those are stable.
I think there are several more functions that could safely have their
arguments or return values changed.  Now, I don't mean to be pushing
us back to essentially writing C code in C++ and ignoring the benefits
of C++.  For places where dynamic storage is needed, as for a class
member, using std::string is a big advantage and not a problem.  Just
be cognizant of the costs where it is used.
3. As I mentioned in an earlier message, there is another 40K of RAM
available for dynamic allocation by code that only requires 32-bit
access, not byte-access.  This is in IRAM (Instruction RAM).  It won't
be allocated by 'malloc' or 'new' but can be allocated explicitly with
pvPortMallocCaps(sizeof(size, MALLOC_CAP_32BIT).  I'm currently using
part of it for the storage of metadata about blocks allocated from the
heap in the ovms_module debugging code to minimize the impact that
using that code has on the memory available for the code to be tested.
