[Ovmsdev] V3 progress
Tom Parker tom at carrott.org
Tue Oct 10 18:39:20 HKT 2017
On 10/10/17 02:17, Mark Webb-Johnson wrote:
> But that seems strange. Is it ms_v_bat_current or ms_v_bat_i?
Oops, I originally added voltage and current as ms_v_bat_v and
ms_v_bat_i, and you spelled out voltage, so I removed my voltage metric
and attempted to update my current metric and missed half the changes.
>> I had trouble with method overloading and hiding in the Metrics
>> classes and ended up giving the AsStringDefault method a unique name.
>> The api I made also seems very clunky, do I really have to make a
>> std::string from a constant and then pass it in? Or is it more
>> idomatic to pass in the constant and turn it into a std::string when
>> and if it is returned?
> I think the standard C++ mechanisms for providing pre-initialised
> default values as parameters should work, so have modified the
> AsString, AsInt, etc functions to use that. It doesn’t change a normal
> call (so current behaviour is unchanged), but does give you a way of
> providing a default value for undefined metrics.
Yes, this is very much what I wanted, it didn't occur to me that C++
supported default values for arguments. I've updated my code to use the
default argument method.
> I re-worked my tpms example, to use std::string:
> What do you think of that? It looks better, but I still don’t really
> like all those append(“,”) lines.
Much better. I too didn't like how the commas were added. I had a read
of https://stackoverflow.com/questions/1430757/c-vector-to-string and
wasn't sure which answer was most appropriate. Given we're going to have
quite a few different v2 messages, I think it is worth serializing each
field in the message into members of an array and then programmatically
serializing that to a comma separated string, such as the following
pastiche of Java and our code:
std:string message[] = {
   StandardMetrics.ms_v_bat_soc->AsString("0"),
   StandardMetrics.ms_v_bat_range_ideal->AsString("0"),
   StandardMetrics.ms_v_bat_range_est->AsString("0"),
buffer = "MP-0 S" + String.join(",", message);
> Can you try to re-work your code, to use these three new things, and
> then re-submit a pull request?
I've reworked it, will test and update the pull request tomorrow.
> I think this is related to the sdkconfig. Anyway, I removed the
> components/spiffs (as we don’t use it), and it now compiles.
> I also created a sdkconfig.default that developers can copy to
> sdkconfig, to provide a good set of defaults. You should also be able
> to diff it, to see anything changed.
Thanks it is compiling again.
I'll test the vfs append tomorrow too
