[Ovmsdev] V3 progress
Tom Parker tom at carrott.org
Mon Oct 9 18:10:46 HKT 2017
On 09/10/17 03:29, Mark Webb-Johnson wrote:
> Do the best you can, and if you can’t work out how to get something in
> particular, let me know or leave it as a “TODO” marked in the code.
Thanks for adding the metrics. I sent a pull request with an initial
implementation of the Stat message. It doesn't use any of your new
metrics except battery voltage (I'd already added that one) and I wedged
sending it into a nearby loop which is almost certainly the wrong place,
but it works and I was able to send telemetry from a real car today
using a wifi hotspot for network connectivity.
I had trouble with method overloading and hiding in the Metrics classes
and ended up giving the AsStringDefault method a unique name. The api I
made also seems very clunky, do I really have to make a std::string from
a constant and then pass it in? Or is it more idomatic to pass in the
constant and turn it into a std::string when and if it is returned?
I don't like the fixed size buffer to construct the message, I copied
the TPMS message code, and not knowing the "right" way to do it in this
embedded C++, I just cargo culted it together. I'd be much happier if we
at least used something that was aware of how big the buffer was and
failed more gracefully than overflowing.
I tried an SD card and it didn't work. How do I hard code or otherwise
inject some startup commands without an SD card? I tried tracing through
the command code but quickly decided it was easier to just start the
vehicle module, wifi and v2 server with my laptop in monitor mode.
Since I rebased onto the current master, things don't compile:
/vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/spiffs/./spiffs_vfs.c:
In function 'vfs_spiffs_fstat':
/vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/spiffs/./spiffs_vfs.c:344:22:
error: 'CONFIG_SPIFFS_LOG_PAGE_SIZE' undeclared (first use in this function)
      st->st_blksize = CONFIG_SPIFFS_LOG_PAGE_SIZE;
