[Ovmsdev] Newbie question & initial report
Sun Oct 8 19:57:35 HKT 2017
I think that is because no network connection available (wifi). Can you try with wifi up, running, and an IP address assigned?
Seems stack gets messed up in that case. I’ll try to find out why, but the backtrace isn’t helping much.
Regards, mark.
> On 7 Oct 2017, at 2:53 PM, Stephen Casner <casner at acm.org> wrote:
> On Fri, 6 Oct 2017, Mark Webb-Johnson wrote:
>> On that topic, I’d appreciate it if those of you with the latest
>> firmware (today’s) can try a ‘ota flash http’ and see if it works
>> for you.
> Crashed:
> OVMS > ota flash http
> Current running partition is: factory
> Target partition is: ota_0
> Download firmware from api.openvehicles.com/firmware/ota/v3/main/ovms3.bin to ota_0
> Error: Request failed
> Guru Meditation Error of type LoadProhibited occurred on core  1. Exception was unhandled.
>                                                      -- Steve_______________________________________________
