[Ovmsdev] V3 progress
Tom Parker tom at carrott.org
Sun Oct 8 17:40:02 HKT 2017
On 04/10/17 02:30, Mark Webb-Johnson wrote:
> I just added the very basic ones, as a starting point and proof of
> concept. Hadn’t decided if I needed anything special for the bitmapped
> ones at the time (either a new MetricBitmap type, or extend
> MetricInt). Looking at how things have evolved, and bearing in mind
> the GAPP bluetooth stuff, and OVMS v3 MQTT, it seems that each bit
> should be a metric of their own. Not too hard for ovms_server_v2 to
> convert that back to an integer bitmap, for backwards compatibility.
> To do that, car_doors1 becomes:
I fully support the concept of storing the data in the most appropriate
format and serializing it into the v2 message in the v2 server code. I
like the idea of storing the bit field stuff as separate boolean
objects. I don't know if you can do anything clever with C++ to use less
memory while preserving a nice API within the vehicle code, but we
probably have enough memory to not need to worry too much?
> So, if you have time, please go ahead and add the other standard ones
> that are simple and shared across all cars.
I'll add them as I need them for porting the leaf code. I don't support
most of the "standard" metrics in the leaf code so it won't be all of them.
>> Is anyone working on the v2 server support code to send the S and D
>> messages?
> Nope. Not at the moment. I’ve stubbed it.
I've implemented an S message using the TPMS as an example and the few
metrics that we already have. I found the android client can't cope with
an empty value, so I had to modify the if undefined return the empty
string behavior in the AsString implementations in subclasses of
OvmsMetric. I'm currently "learning" how C++ inheritance works and am in
a twisty maze of complier errors. I'll explain what I'm doing tomorrow
and hopefully there is an obvious answer. Once I've sorted that out I'll
send a pull request (I hacked it by hard coding values that work for a
v2 android client which presumably breaks other things. What I want to
do is replace the existing methods with ones that takes an argument to
return as a default value, and re-implement the existing no-argument
methods in terms of the new method).
I'm at the point where I can take it for a drive on my phone's wifi hotspot.
