[Ovmsdev] Problems ms_v_charge_mode
Mon Nov 27 08:53:14 HKT 2017
Really need to see the overall context of this. Where are you calling the ms_v_charge_mode->SetValue from?
Probably easiest to commit what you have to your own github clone, then let us know where that is and we can see the whole thing.
> On 26 Nov 2017, at 4:35 AM, Geir Øyvind Vælidalo <geir at validalo.net> wrote:
> I’m having problems setting ms_v_charge_mode.
> I do it this way, but it fails at runtime:
> StdMetrics.ms_v_charge_mode->SetValue( chademo ? "performance" : "standard");
> This is the trace I get, so it seems to fail somewhere else:
> I (6451) events: Signal(vehicle.charge.mGuru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled.
> Register dump:
> PC : 0x400883c3 PS : 0x00060633 A0 : 0x8008708a A1 : 0x3ffc6b30
> 0x400883c3: vListInsertEnd at /Users/goev/esp/esp-idf/components/freertos/./list.c:130
> A2 : 0x3ffc6384 A3 : 0x3ffc6c78 A4 : 0x00060620 A5 : 0x00000000
> A6 : 0x00000000 A7 : 0x00000000 A8 : 0x00000038 A9 : 0x3ffb33b8
> A10 : 0x3ffb131c A11 : 0x00060623 A12 : 0x00060623 A13 : 0x3ffce1ec
> A14 : 0x3ffce1ec A15 : 0x3ffc6a70 SAR : 0x00000010 EXCCAUSE: 0x0000001c
> EXCVADDR: 0x00000040 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xfffffffa
> Backtrace: 0x400883c3:0x3ffc6b30 0x40087087:0x3ffc6b50 0x400860f1:0x3ffc6b70 0x4008771b:0x3ffc6b90 0x40087818:0x3ffc6bc0
> 0x40087087: vTaskPlaceOnEventListRestricted at /Users/goev/esp/esp-idf/components/freertos/./tasks.c:4446
> 0x400860f1: vQueueWaitForMessageRestricted at /Users/goev/esp/esp-idf/components/freertos/./queue.c:2392
> 0x4008771b: prvProcessTimerOrBlockTask at /Users/goev/esp/esp-idf/components/freertos/./timers.c:839
> 0x40087818: prvTimerTask at /Users/goev/esp/esp-idf/components/freertos/./timers.c:839
> It looks like it has something to do with the Signal event, but I ‘m still not that good using gbd to find out what actually makes this fail.
> Any one got a clue?
> Geir
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171127/9f41476a/attachment.htm>
