[Ovmsdev] Notifications concept draft
Sun Nov 5 17:39:41 HKT 2017
Some thoughts about how to implement vehicle notifications and data logging. Please check & comment.
Concept:
- handle all unsolicited transmissions from vehicles by commands
- vehicle module signals event if a transmission is due
- … with event data = command line to generate output
- listeners retrieve the transmission content by executing the command
- queueing for async delivery is done by the listeners (i.e. through BufferedShell)
→ any shell command can be used for transmissions
→ all transmissions can also be generated on the shell / by script
→ all transmission output can be sent to any channel
→ data logging on SD can be done transparently by the system
Interactive consoles can output unsolicited transmissions by event type
according to the current log level.
Events:
"send.info" → send text notification
"send.alert" → send text alert
"send.data" → send data record (CSV, content part of v2 MP)
Scheme:
MyEvents.SignalEvent("send.<type>", "command [args]");
Examples:
MyEvents.SignalEvent("send.info", "stat");
MyEvents.SignalEvent("send.alert", "xrt batt status");
MyEvents.SignalEvent("send.data", "xrt log RT-BAT-C");
→ command output:
H,RT-BAT-C,4,86400,1,1,4025,3675,4045,5,14,14,19,1
