[Ovmsdev] Stat command
Sat Nov 4 17:51:43 HKT 2017
I've added a default implementation for the "stat" command.
virtual vehicle_command_t CommandStat(int verbosity, OvmsWriter* writer);
I thought about letting the vehicle module generate a std::string, but it would still need the verbosity and would always need another memory buffer, so I think
passing the writer to vehicle methods generating output is better -- please correct me if there is a system design decision I'm breaking with this.
Am 30.10.2017 um 07:06 schrieb Mark Webb-Johnson:
> I’ve implemented these standard commands in vehicle framework:
> virtual vehicle_command_t CommandSetChargeMode(vehicle_mode_t mode);
> virtual vehicle_command_t CommandSetChargeCurrent(uint16_t limit);
> virtual vehicle_command_t CommandStartCharge();
> virtual vehicle_command_t CommandStopCharge();
> virtual vehicle_command_t CommandSetChargeTimer(bool timeron, uint16_t timerstart);
> virtual vehicle_command_t CommandCooldown(bool cooldownon);
> virtual vehicle_command_t CommandWakeup();
> virtual vehicle_command_t CommandLock(const char* pin);
> virtual vehicle_command_t CommandUnlock(const char* pin);
> virtual vehicle_command_t CommandActivateValet(const char* pin);
> virtual vehicle_command_t CommandDeactivateValet(const char* pin);
> virtual vehicle_command_t CommandHomelink(uint8_t button);
> Also implemented most of these for the Tesla Roadster, as an example implementation.
> I haven’t changed ovms_server_v2 yet, to implement the standard command processor for these, but that should be trivial.
> Vehicle modules are able to implement handlers for these standardised commands, as well as their own custom commands (if required).
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171104/dbfbc7c3/attachment.htm>
