[Ovmsdev] StdMetrics.ms_v_env_parktime
Mon Nov 27 16:56:15 HKT 2017
Oh, I meant that we could just use ms_v_charge_state as a trigger to know when to reset/update ms_v_charge_minutes. Nothing more than that.
Sorry for being a little bit unclear!
Best regards,
Geir
Sendt fra min iPhone
> 26. nov. 2017 kl. 06:11 skrev Mark Webb-Johnson <mark at webb-johnson.net>:
> For ms_v_charge_minutes, yes. I’ve changed that, and pushed.
> The ms_v_charge_state is a description of the charge state (along with the ms_v_charge_substate).  I think that needs to be controlled by the vehicle module. I do see a duplication with the boolean states (such as pilot signal, charging, heating, etc), but the ms_v_charge_state may reflect the _last_ charge state change, not necessarily current charge state (for example; done/stopped). Need to think about this. Not so simple.
>> On 24 Nov 2017, at 7:11 PM, Geir Øyvind Vælidalo <geir at validalo.net> wrote:
>> I agree, Mark. That was a clean solution.
>> Shouldn't we do the same with ms_v_charge_state and ms_v_charge_minutes too?
>> Geir
>>> I think in general things like this should be handled in the common
>>> vehicle code, rather than all vehicle modules. In this case, the vehicle
>>> module control v.e.on and park time can be maintained centrally
>>> (irrespective of the vehicle type).
>>> Given the v3 server code, it makes more sense for park time in v3 to mean
>>> number of seconds since vehicle was parked (like in the protocol for v2).
>>> I’ve added that logic into vehicle.cpp, and updated the other vehicle
>>> modules not to change it at all. I’ve also fixed ovms_server_v2 to
>>> handle it correctly.
>>>> On 24 Nov 2017, at 5:55 AM, Geir Øyvind Vælidalo <geir at validalo.net>
>>>> wrote:
>>>> «Quick» question:
>>>> StdMetrics.ms_v_env_parktime, is it seconds since the car was parked,
>>>> which means we should update it in Ticker1? Or is it the time when the
>>>> car was parked?
>>>> Looking at V2 and the OVMS-V2conversion in V3, it looks to me like the
>>>> first, but looking at the Twizy-module it looks like the latter.
>>>> I guess setting the start time should be enough. When sending packets to
>>>> V2-server, we could easily calculate the seconds:
>>>> time(NULL)-ms_v_env_parktime. Unless ms_v_env_parktime is 0, then
>>>> we’re not parked.
>>>> The same could then be done for ms_v_charge_minutes too.
>>>> Geir
>>>> OvmsDev mailing list
