[Ovmsdev] Problems ms_v_charge_mode
Mon Nov 27 16:18:45 HKT 2017
Ok, Mark, I've committed my latest version to
https://github.com/goev/Open-Vehicle-Monitoring-System-3
Everything I've done is in vehicle_kiasoulev.
I set the charge mode in a function called SetChargeMetrics. It is called
from Ticker1 when ks_charge_bits.ChargingJ1772 or
ks_charge_bits.ChargingChademo is true.
(Un)fortunately ks_charge_bits is uninitialized and probably contains some
garbage, so it usually fires the call to SetChargeMetrics when running
"vehicle module KS"
even when not connected to the car. I need to set a default value to the
ks_charge_bits and probab some more ks_-variables in the constructor, but
I haven't come that yet.
NB! In SetChargeMetrics, I've commented out the charge mode-line, so you
need to remove the comment-tag and comment.
Yesterday I also found out that ms_v_charge_state gives similar problems.
It was *really* late, so I didn't look to close into it, but it seemed
related.
I've added a macro in vehicle_kiasoulev.h called SET_CHARGE_STATE where
I've commented out the setting of the charge state, in case you find time
to look into that too.
Thanks!
Geir
> Really need to see the overall context of this. Where are you calling the
> ms_v_charge_mode->SetValue from?
> Probably easiest to commit what you have to your own github clone, then
> let us know where that is and we can see the whole thing.
>> On 26 Nov 2017, at 4:35 AM, Geir Øyvind Vælidalo <geir at validalo.net>
>> wrote:
>> I’m having problems setting ms_v_charge_mode.
>> I do it this way, but it fails at runtime:
>>   StdMetrics.ms_v_charge_mode->SetValue( chademo ? "performance" :
>> "standard");
>> This is the trace I get, so it seems to fail somewhere else:
>> I (6451) events: Signal(vehicle.charge.mGuru Meditation Error of type
>> LoadProhibited occurred on core  0. Exception was unhandled.
>> Register dump:
>> PC      : 0x400883c3  PS      : 0x00060633  A0      : 0x8008708a  A1
>>  : 0x3ffc6b30
>> 0x400883c3: vListInsertEnd at
>> /Users/goev/esp/esp-idf/components/freertos/./list.c:130
>> A2      : 0x3ffc6384  A3      : 0x3ffc6c78  A4      : 0x00060620  A5
>>  : 0x00000000
>> A6      : 0x00000000  A7      : 0x00000000  A8      : 0x00000038  A9
>>  : 0x3ffb33b8
>> A10     : 0x3ffb131c  A11     : 0x00060623  A12     : 0x00060623  A13
>>  : 0x3ffce1ec
>> A14     : 0x3ffce1ec  A15     : 0x3ffc6a70  SAR     : 0x00000010
>> EXCCAUSE: 0x0000001c
>> EXCVADDR: 0x00000040  LBEG    : 0x400014fd  LEND    : 0x4000150d  LCOUNT
>>  : 0xfffffffa
>> Backtrace: 0x400883c3:0x3ffc6b30 0x40087087:0x3ffc6b50
>> 0x400860f1:0x3ffc6b70 0x4008771b:0x3ffc6b90 0x40087818:0x3ffc6bc0
>> 0x40087087: vTaskPlaceOnEventListRestricted at
>> /Users/goev/esp/esp-idf/components/freertos/./tasks.c:4446
>> 0x400860f1: vQueueWaitForMessageRestricted at
>> /Users/goev/esp/esp-idf/components/freertos/./queue.c:2392
>> 0x4008771b: prvProcessTimerOrBlockTask at
>> /Users/goev/esp/esp-idf/components/freertos/./timers.c:839
>> 0x40087818: prvTimerTask at
>> It looks like it has something to do with the Signal event, but I ‘m
>> still not that good using gbd to find out what actually makes this fail.
>> Any one got a clue?
>> Geir
