[Ovmsdev] StdMetrics.ms_v_env_parktime
Fri Nov 24 05:55:21 HKT 2017
«Quick» question:
StdMetrics.ms_v_env_parktime, is it seconds since the car was parked, which means we should update it in Ticker1? Or is it the time when the car was parked?
Looking at V2 and the OVMS-V2conversion in V3, it looks to me like the first, but looking at the Twizy-module it looks like the latter.
I guess setting the start time should be enough. When sending packets to V2-server, we could easily calculate the seconds: time(NULL)-ms_v_env_parktime. Unless ms_v_env_parktime is 0, then we’re not parked.
The same could then be done for ms_v_charge_minutes too.
Geir
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171123/1abefd7a/attachment.html>
