[Ovmsdev] A promiscous wifi client
Tom Parker tom at carrott.org
Thu Nov 9 17:52:39 HKT 2017
On 09/11/17 18:38, Mark Webb-Johnson wrote:
> I’ve committed a change to the esp32wifi component, to try to support
> a promiscuous mode for the wifi client. This should make it work the
> way it does on cellphones, computers, and pretty much all equipment.
> Rather than specifying a specific wifi AP to connect to, it just
> connects to whichever it can (based on where it has connected to in
> the past).
Nice! This is much better than the terrible network manager I wrote.
If you trigger it from a startup script then it never connects because
monotonictime is 0 which doesn't pass the test in EventTimer10(). I'm
running with the following patch, but you might want to start
monotonictime at 1, or not overload a boolean into m_nextscan.
diff --git a/vehicle/OVMS.V3/components/esp32wifi/esp32wifi.cpp
b/vehicle/OVMS.V3/components/esp32wifi/esp32wifi.cpp
index 236f4c9..c6ebcd4 100644
--- a/vehicle/OVMS.V3/components/esp32wifi/esp32wifi.cpp
+++ b/vehicle/OVMS.V3/components/esp32wifi/esp32wifi.cpp
@@ -262,7 +262,9 @@ void esp32wifi::StartScanningClientMode()
    memset(&m_wifi_apsta_cfg,0,sizeof(m_wifi_apsta_cfg));
    ESP_ERROR_CHECK(esp_wifi_start());
-  m_nextscan = monotonictime;
+  // if we are triggered by a startup script, monotonictime will be
zero which
+  // won't pass the test in EventTimer10()
+  m_nextscan = monotonictime == 0 ? 1 : monotonictime;
  void esp32wifi::StartAccessPointMode(std::string ssid, std::string
password)
If there is a network in range that has the same name as a network that
is saved but has a different password, the client never tries the next
network. Instead it tries to connect to the "fake" network over and over
and over. It appears to use the network that is alphabetically first in
the list, which isn't good if it knows about an AndroidAP and there
happens to be someone else's AndroidAP switched on while you're trying
to connect to a network with a name that doesn't start with A.
