[Ovmsdev] v2 android clients crashes while v3 is charging
Tue Nov 7 09:57:59 HKT 2017
Probably best to double-check in the iOS and Android Apps for what they use.
For iOS, all I see is a check for chargesubstate == 0x07. Same for Android.
I think it is ok just to use those substates for the moment. Long-term, we don’t really want/need this substate metric anyway.
> On 7 Nov 2017, at 6:01 AM, Michael Balzer <dexter at expeedo.de> wrote:
> I've just pushed a rework of the v2 stat message including some more metrics and automatic code/key translations for charge state & mode.
> It works well on my test vehicle. The translation utilities can also be used to set the code metrics if you stick to the integer keys internally.
> Still missing is the substate. From the v2 code it can have these values:
> - 0 = undefined
> - 1 = charge stop request
> - 3 = charging by request
> - 7 = cable not connected
> - 14 = charge interrupted
> That's a bit mixed scope… are these all substates to support?
> Am 06.11.2017 um 18:37 schrieb Michael Balzer:
>>>>> I also sent another pull request for a minimal implementation of the charger state related values in the v2 protocol, and some small leaf fixes.
>>> This pull request ( https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/7 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/7> ) is still outstanding
>> I think deriving the car_chargestate string from the charge flags is not correct. We've currently got…
>> OvmsMetricString* ms_v_charge_state; // charging, topoff, done, preparing, heating, stopped
>> OvmsMetricString* ms_v_charge_mode; // standard, range, performance, storage
>> OvmsMetricString* ms_v_charge_substate; // tba...
>> …but no longer their numerical equivalences as metrics -- assuming they are no longer necessary. Are they? I.e. do we need the numerical values other than for
>> the old V2 protocol?
>> I'd else translate the old codes to their old numerical values just for the "S" msg.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171107/ed05012f/attachment.html>
