[Ovmsdev] Notifications concept draft
Sun Nov 5 17:39:41 HKT 2017
Some thoughts about how to implement vehicle notifications and data logging. Please check & comment.
Concept:
  - handle all unsolicited transmissions from vehicles by commands
  - vehicle module signals event if a transmission is due
  - … with event data = command line to generate output
  - listeners retrieve the transmission content by executing the command
  - queueing for async delivery is done by the listeners (i.e. through BufferedShell)
  → any shell command can be used for transmissions
  → all transmissions can also be generated on the shell / by script
  → all transmission output can be sent to any channel
  → data logging on SD can be done transparently by the system
Interactive consoles can output unsolicited transmissions by event type
according to the current log level.
Events:
  "send.info"      → send text notification
  "send.alert"     → send text alert
  "send.data"      → send data record (CSV, content part of v2 MP)
Scheme:
  MyEvents.SignalEvent("send.<type>", "command [args]");
Examples:
  MyEvents.SignalEvent("send.info", "stat");
  MyEvents.SignalEvent("send.alert", "xrt batt status");
  MyEvents.SignalEvent("send.data", "xrt log RT-BAT-C");
  → command output:
    H,RT-BAT-C,4,86400,1,1,4025,3675,4045,5,14,14,19,1
