[Ovmsdev] Fwd: v3
Frank Demes frank.demes at gmx.de
Wed May 17 16:36:45 HKT 2017
Germany:
T-Mobile:
2G (until 2025) 900/1800
3G (until 2020) 2000 !
4G/LTE (until 2025) 800/1800/2600
New but not defined : 700/1500 (until 2033)
Vodafone:
3G (until 2025) 2000
4G/LTE (until 2025) 800/2600 !
Telfonica(E-Plus/O2):
New but not defined : 700 (until 2033) !
> Am 17.05.2017 um 09:35 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
> For the development modem, I’ve chosen a simple SIMCOM SIM5360 3G modem. Just something to get us started with. The board we are making will also support a SIM7100 4G modem chip as well. Most recent SIMCOM modules are compatible.
> Specifications for the modem are here:
> http://simcomm2m.com/En/module/detail.aspx?id=82 <http://simcomm2m.com/En/module/detail.aspx?id=82>
> There are three models available:
> SIM5360A
> Dual-Band UMTS/HSPA+ 850/1900MHz
> SIM5360(J)E
> Dual-Band UMTS/HSPA+ 900/2100MHz
> SIM5360J(D)
> Dual-Band UMTS/HSPA+ 800(850)/2100MHz
> The 2G frequencies are all quad-band (GSM/GPRS/EDGE 850/900/1800/1900MHz). The only difference is the dual-band UMTS/HSPA+ frequencies 850/1900MHz, 900/2100MHz, or 800(850)/2100MHz.
> Hong Kong uses:
> https://www.frequencycheck.com/carriers/csl-hong-kong <https://www.frequencycheck.com/carriers/csl-hong-kong>
> Name	Interface
> B1 (2100) <https://www.frequencycheck.com/bands/umts-hspa-band-1-2100>	UMTS <https://www.frequencycheck.com/interfaces/umts-hspa>
> B8 (900 GSM) <https://www.frequencycheck.com/bands/umts-hspa-band-8-900-gsm>	UMTS <https://www.frequencycheck.com/interfaces/umts-hspa>
> So, the first development modem I am getting is SIM5360(J)E.
> For other developers, who will be wanting early OVMS v3 modules, where do you live, what cellular carrier do you use, and what frequencies do you use?
> <[Ovmsdev] v3.eml>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20170517/5811deb2/attachment.htm>
