[Ovmsdev] OVMS v3 First Board Layout
Mon May 8 19:36:31 HKT 2017
Both SIM7000C (LTE-M) and SIM5320 (3G) are available include GPS/GNSS functionality. Price of the SIM7000C is about 50% more expensive than SIM5320. They are very compatible at the pin level so not hard to support both.
Longer-term LTE-M sounds good, but I think maybe too early for this today (even if networks available, how easy is it to get a data plan?).
> On 8 May 2017, at 3:18 PM, Dominik Westner <me at nikwest.de> wrote:
> It is supposed to be rolled out across Europe over the next months. In US it already seems to be available.
> As this is a software only feature of the existing infrastructure it shouldn't take too long. But that information is only second hand.
> I'm mostly following what these guys are doing
> https://www.pycom.io/pycom-and-canonical-to-enable-lpwan-communications-via-snaps/ <https://www.pycom.io/pycom-and-canonical-to-enable-lpwan-communications-via-snaps/>
> Sent from my iPad
> On 8. May 2017, at 08:42, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>> LTE-M
>> Is that ‘prime time’ already? I thought that wasn’t gonna be ready for another year or so (on a large scale, globally).
>> There is a SIMCOM module for LZTE-M (SIM7000C), with GNSS (GPS) and 2G but no 3G, but that is really new.
>> My concern with LTE is that there are still lots of areas with no 4G coverage, so fallback to 3G seems necessary.
>> Mark.
>>> On 8 May 2017, at 2:18 PM, Dominik Westner <me at nikwest.de <mailto:me at nikwest.de>> wrote:
>>> Isn't LTE-M the way to go?
>>> Something like the sequans monarch?
>>> http://www.sequans.com/products-solutions/streamlitelte/monarch-lte-platform/ <http://www.sequans.com/products-solutions/streamlitelte/monarch-lte-platform/>
>>> On 8. May 2017, at 07:41, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>> The side project of looking at 3G/4G modems has also started. This is going to be on one of those optional expansion slots to allow us to use different modems for different functions. I’m used to SIMCOM, but it seems their selection is getting complicated (particularly for 4G). I see the SIM5320A has 3G and GPS, which seems good but is quite dated now.
>>>> SIM5320A:Dual-Band UMTS/HSDPA 850/1900MHz, Quad-Band GSM/GPRS/EDGE 850/900/1800/1900MHz
>>>> SIM5320(J)E:Dual-Band UMTS/HSDPA 900/2100MHz, Quad-Band GSM/GPRS/EDGE 850/900/1800/1900MHz
>>>> SIM5320J:Dual-Band UMTS/HSDPA 850(800)/2100MHz Quad-Band GSM/GPRS/EDGE 850/900/1800/1900MHz
>>>> It does have the CMUX, which is very nice (gives us four virtual ports over the single async port, so easier to deal with AT command control).
>>>> If anyone has any suggestions for the modem, it would be helpful. Something with GPS would be ideal.
>>>> Regards, Mark.
>>>> <OVMS_V3_Schematic_CN_20170503.pdf>
>>>> <OVMS_V3_Layout_CN_20170508.pdf>
>>>> OvmsDev mailing list
>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20170508/dde27d00/attachment.htm>
