[Ovmsdev] V3 size and arrangement
Fri May 19 20:49:58 HKT 2017
Perhaps I can ask for two holes on each of the expansion slots (and lined up with holes on the expansion cards). Then we could use simple stand-offs if required.
I’ll add it to the list of things to ask the factory what they think.
> On 19 May 2017, at 8:00 PM, Edward Cheeseman <cheesemanedward at gmail.com> wrote:
> On 19/05/2017, at 10:48 PM, Mark Webb-Johnson wrote:
>> Really? Even with two rows of 14pin SIP socket? That is pretty robust. I can ask what the manufacturer recommends.
> Automotive is a high vibration environment, and friction alone can work loose. Maybe a recommendation to use a bit of hot glue, or cram some foam between the expansion boards and case would be more than sufficient.
> So again, probably don't bother as there are simple ways of fixing it if it ever becomes an issue.
> Edward
