[Ovmsdev] Framework V3.1
Wed Jan 4 21:50:58 HKT 2017
OK. That was a bit of a mess and took some tidying up.
I moved NissanLeaf and Mitsubishi to production (and removed them from experimental).
Also fixed a small twizy compilation issue (for compiling without twizy config option enabled).
Memory status is now:
V1_Production: 91% data, 92% program
V2_Experimental: 99% data, 85% program
V2_Production: 96% data, 76% program
V2_TR_Production: 93% data, 76% program
V2_RT_Production: 97% data, 100% program - about 130 bytes free
All pushed to github.
> On 4 Jan 2017, at 9:11 AM, Mark Webb-Johnson <mark at openvehicles.com> wrote:
>> Maybe it's time to move the Leaf & Mitsubishi modules to the production
>> build? Is there anything still experimental about them?
> I will have a look at this tonight, and move things around as necessary.
>> On 4 Jan 2017, at 7:57 AM, Michael Balzer <dexter at expeedo.de> wrote:
>> Sorry, haven't done a batch build before checking in...
>> Your description matches what could happen with the buffer bug.
>> Regarding the App crashing: hardening it against garbage data is on my
>> list. It happened also with the buffer bug on the Twizy, because the
>> data parser is a bit too strict.
>> Btw: I've been in contact with an enthusiastic Leaf owner named Slava
>> from the Ukraine, told him to get in contact with you. He thinks about
>> setting up an OVMS server for his region. As you may have guessed, there
>> is no NissanConnect in the Ukraine... ;)
>> Am 03.01.2017 um 23:55 schrieb Tom Parker:
>>> On 03/01/17 00:44, Michael Balzer wrote:
>>>> As you may have seen, I submitted a rework of the network framework
>>>> yesterday.
>>> The experimental firmware doesn't build anymore -- there isn't enough
>>> space during linking. I removed some of the other cars and it builds
>>> again, do we need to split the experimental configuration in two?
>>> At the weekend I rebased onto master immediately prior to your changes
>>> and then managed to mess up my OVMS while doing some development, I
>>> haven't looked into what happened but I saw garbage messages relayed
>>> through the server, the OVMS android app crashed on startup (sorry no
>>> logs), many "Vehicle authentication failed" messages by email and also
>>> a "Vehicle is stopped turned on" via SMS and email (I'm using Dexter's
>>> server which sends me emails sometimes).
>>> I'm not sure if I ran some bad code of my own or if I fell victim to
>>> the buffer problem you've hopefully fixed. My OVMS has been very solid
>>> for the last 6 months or so, but I haven't taken any updates until the
>>> weekend.
>>> I'll read out the EEPROM and test with your updated framework tomorrow.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20170104/36358ffd/attachment.htm>
