[Ovmsdev] SIM808 GPS float bug
Tue Jan 24 01:49:18 HKT 2017
Hi Edward,
welcome :)
I do notice some offset from road maps once in a while. So go ahead
optimizing gps2latlon(), maybe that's the offset source.
The atof() function should be fixed regardless of the GPS conversion,
I'll take care of that.
Am 23.01.2017 um 08:12 schrieb Edward Cheeseman:
> Hello,
> I am new to OVMS. I have a Gen2 Leaf on Dexters server. Tom has helped
> me set it up.
> I found my GPS data was off up to two degrees. I’ve traced it to
> myatof() in utils.c.
> It adds the fractional part with both positive and negative numbers,
> where it should subtract for negative numbers.
> myatof() is used in SIM808 lat and long conversions, and somewhere in
> Twizy which I didn’t look into.
> I suppose there isn’t that many SIM808 based OVMSs in the Southern or
> Western hemispheres?
> It is easy to fix, but maybe going through float in the first place
> isn’t necessary?
> Looks like there is 31bits of information coming out of the GPS where
> float will drop this to 23bits.
> I’ve started rewriting gps2latlon() to use a long long (64bit) integer
> multiply and divide.
> I see reference to SIM808 and 908 on an arduino shield, so I might
> have a look to see what they have done.
> Edward
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20170123/e5f26948/attachment.html>
