[Ovmsdev] Framework V3.1
Tom Parker
tom at carrott.org
Sat Jan 7 16:30:17 HKT 2017
Interesting. I haven't changed anything in that code for a long time,
but I also hadn't noticed it was causing problems so might have been
broken for a long time? How do I see these errors? Running my own
server? Watching the comms with the modem?
It's supposed to send me up to the most recent of 3 different CAN frames
(chosen at compile time), once per minute. Looking through the server
logs (nice email feature on your server) I see it fairly reliably sends
the first frame each minute, but usually not the others. The car is
moving, so it's on, so all three frames are present on the bus, so I'm
reasonably sure it is trying to send the other 2. I'm sending 3 messages
one after the other in this code triggered from ticker60
https://carrott.org/git/Open-Vehicle-Monitoring-System.git/blob/refs/heads/report-more-data:/vehicle/OVMS.X/vehicle_nissanleaf.c#l241
Can I just send messages one after the other? The message framework
was... complicated. I see in the twizzy telemetry it may only send one
message each time it's called?
On 07/01/17 08:52, Michael Balzer wrote:
> Tom,
> I did some more log digging:
> a) Since yesterday, your log entries haven't contained any garbage
> characters.
> b) "Unable to decode" messages now/still occur on a regular and quite
> predictable base.
> The rule seems to be: the next message sent by the car after a "H
> NL-COM-CAN" message will be broken.
> This happens independant of the time span between the "H" message and
> the next, and as the following messages are of varying sizes also
> independant of the message type.
> So this looks like a memory corruption coupled to the "H NL-COM-CAN"
> message generation process, that kills your encryption (or more...).
> Examples:
> 2017-01-06 07:40:32.557128 +0100 info main: #26 C NZLLEAF rx msg H
> NL-COM-CAN,3,86400,054A120070020000003B
> 2017-01-06 07:41:13.198896 +0100 info main: #26 C NZLLEAF rx
> 6Rm2CahmvSvTu/P7nJMLkUiRqFS1rww6BrxQY7zBF0sQwamaOHBMRbuWby0Gs8P9nrMcW45Ft73uZT93u6sHGTOkUgcdh/fzeGF4gcPSpql4/cC+bksNFJKEjykWVMLJ+cNrvlh5E7DCmA==
> 2017-01-06 07:41:13.199028 +0100 error main: #26 NZLLEAF error -
> Unable to decode message - aborting connection
> 2017-01-06 13:10:03.385363 +0100 info main: #41 C NZLLEAF rx msg H
> NL-COM-CAN,3,86400,054AA00070020000003A
> 2017-01-06 13:10:12.587657 +0100 info main: #41 C NZLLEAF rx
> zZ186U6RmvLkP272bNAP5xk3bRXt5P6Z/X+F86EaNtymnduvZT1o2UKu6+r4LUDGRCXe4vd/jQ==
> 2017-01-06 13:10:12.587918 +0100 error main: #41 NZLLEAF error -
> 2017-01-06 20:35:34.710329 +0100 info main: #68 C NZLLEAF rx msg H
> NL-COM-CAN,3,86400,054A1200700200000039
> 2017-01-06 20:35:39.556488 +0100 info main: #68 C NZLLEAF rx
> Tl4PXkvivM+Iq+eeIgNCHKcwqUhY4i/+0igGrXgx/kR89xTBlY3uYQVwRXZfZQnvwDAi+IsojhjncnNVDDhEZ9B6YTv/RGjtx0qdtAEOwBEQPRIwejEtBnNaHpNu8Cu2dwHDUQ8c
> 2017-01-06 20:35:39.556746 +0100 error main: #68 NZLLEAF error -
> Am 05.01.2017 um 13:20 schrieb Michael Balzer:
>> Also, the "S" corruption originates from just a single wrong
>> character inserted in the encoded protocol message, i.e.
>> +cGF352j_<F3>_FeLiJ59cMLlOXpRJhGa7sMGM9Rg/WeXeJuwKGCiuqv8p4FVNCKiHEsEnf9WeNbnm6JGPz7yxD7KjlQtOSVFtHXH2DGUa+C0x5ZaZRiSv6HpLxBkvIEBEu0f4EBPjF+X
>> or
>> +dUShf7R71hcb7msV8SCXu55xEwG9Z3Dx9G4UNuO9V7t7JFnGYwSmrf5aWouO+rm1PdZfQgLENbGLMVbv/tRfkEA+vZRPapkU_<DB>_KSO92hqvnrVcgJOVYNiglaXPqMt92lKXatEVO1
>> -- IMO that cannot originate from the base64 encoding, so can only
>> come from some UART TX related problem (?)
>> May be a serial log can show what's happening here.
>> Am 05.01.2017 um 13:06 schrieb Michael Balzer:
>>> Tom,
>>> from my logs archive:
>>> a) I found "duplicate car login" and "unable to decode" errors from
>>> your car beginning on 2016-12-14 15:50 (UTC)
>>> ...that was with firmware 2.8.7/NL1.0/V2/V2E9
>>> b) garbage characters first occurred in the "S" messages beginning
>>> with 2017-01-01 12:16
>>> ...that was right after changing your firmware to 2.9.2/NL1.0/V2/V2E9
>>> The "L" message corruptions due to the stp_l2f bug started on
>>> 2017-01-04 03:05 with 3.1.1/NL1.0/V2/V2E9.
>>> The "S" corruptions only occur with your car (on my server).
>>> My earliest log kept is from 2016-12-10, and your car messages were
>>> clean and error free until 2016-12-14 15:50.
>>> Can you tell what has changed on 2016-12-14 15:50?
>>> Am 05.01.2017 um 04:08 schrieb Tom Parker:
>>>> On 05/01/17 02:00, Michael Balzer wrote:
>>>>> Checking the server log I found another bug I introduced some time
>>>>> ago in the server push notification code.
>>>>> I just restarted the fixed server, tell me if the authentication
>>>>> notifications still occur.
>>>> The authentication success/failed messages are still occurring.
>>>> At 10:39 today I got a trunk open while in valet mode alert via SMS
>>>> but not via email and communication stopped. I'm not setting the
>>>> trunk or valet bits in the leaf firmware.
>>>> I'm logging the server traffic with client.pl and I see this, where
>>>> <FA> represents the raw hex 0xfa and ^E is probably whatever ctrl-e
>>>> is.
>>>> Thu Jan 5 10:29:24 2017 Server message decodes to: MP-0 T0
>>>> S77,K,0,0,stopped,standard,105,0,0,0,0,0,0,0,0,0,0,-1,0.00,-1,-1,0,0,-1,0,0,-1,-1<FA>_<8D>D<80>~^^D<A0>^Ev<D7>O<FA>
>>>> ~^N
>>>> Thu Jan 5 10:29:24 2017 Server message decodes to: MP-0 Z0
>>>> Thu Jan 5 10:29:35 2017 Server message decodes to: MP-0 Z1
>>>> Thu Jan 5 10:39:25 2017 Server message decodes to: MP-0 Z0
>>>> I think there must still be a corruption bug somewhere. It might be
>>>> time to bisect.
>>>> OvmsDev mailing list
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20170107/4ac819d4/attachment-0001.html>
