[Ovmsdev] Framework V3.1
Mark Webb-Johnson mark at openvehicles.com
Wed Jan 4 09:11:23 HKT 2017
> Maybe it's time to move the Leaf & Mitsubishi modules to the production
> build? Is there anything still experimental about them?
I will have a look at this tonight, and move things around as necessary.
> On 4 Jan 2017, at 7:57 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Sorry, haven't done a batch build before checking in...
> Your description matches what could happen with the buffer bug.
> Regarding the App crashing: hardening it against garbage data is on my
> list. It happened also with the buffer bug on the Twizy, because the
> data parser is a bit too strict.
> Btw: I've been in contact with an enthusiastic Leaf owner named Slava
> from the Ukraine, told him to get in contact with you. He thinks about
> setting up an OVMS server for his region. As you may have guessed, there
> is no NissanConnect in the Ukraine... ;)
> Am 03.01.2017 um 23:55 schrieb Tom Parker:
>> On 03/01/17 00:44, Michael Balzer wrote:
>>> As you may have seen, I submitted a rework of the network framework
>>> yesterday.
>> The experimental firmware doesn't build anymore -- there isn't enough
>> space during linking. I removed some of the other cars and it builds
>> again, do we need to split the experimental configuration in two?
>> At the weekend I rebased onto master immediately prior to your changes
>> and then managed to mess up my OVMS while doing some development, I
>> haven't looked into what happened but I saw garbage messages relayed
>> through the server, the OVMS android app crashed on startup (sorry no
>> logs), many "Vehicle authentication failed" messages by email and also
>> a "Vehicle is stopped turned on" via SMS and email (I'm using Dexter's
>> server which sends me emails sometimes).
>> I'm not sure if I ran some bad code of my own or if I fell victim to
>> the buffer problem you've hopefully fixed. My OVMS has been very solid
>> for the last 6 months or so, but I haven't taken any updates until the
>> weekend.
>> I'll read out the EEPROM and test with your updated framework tomorrow.
