[Ovmsdev] SIM808/SIM908 GPS accuracy
HONDA S-2000 s2000 at audiobanshee.com
Tue Feb 7 05:53:11 HKT 2017
Hi Edward,
32-bit float does indeed store 23 bits of significand, but there is an additional implicit bit, making the total 24 bits. When you also consider the separate sign bit, 32-bit float has as much precision as a 25-bit signed fixed-point integer.
Adjusting your math without any other adjustments, that would imply a resolution of 1.2 meters and perhaps 2.5 meters unrounded.
However, I don't quite follow your calculations since floating point always carries a certain number of significant digits, regardless of the exponent. Can you show why the circumference divided by a fixed precision would reflect the ability and precision of a floating point calculation? It's a snowy day here, and I don't have my floating point thinking cap...
Brian
On Feb 1, 2017, at 12:38 PM, Edward Cheeseman <cheesemanedward at gmail.com> wrote:
> So, given the floating point library has been pulled in anyway, I think the current implementation isn’t too bad.
> Floating point accuracy:
> - The equatorial circumference of the Earth is 40,075,017 meters.
> - Divided by 23bit, resolution is 4.8meters
> The math is probably unrounded, so probably the best you could hope for is within 10 meters.
