    Sun Dec 31 01:33:58 HKT 2017
Do you get valid messages with the previous version?
Am 30.12.2017 um 18:30 schrieb Geir Øyvind Vælidalo:
> Ok, this is what I get. As you can see, it is the same.
> OVMS >can can2 start active 100000
> Can bus can2 started in mode active at speed 100000Kbps
> V (740558) can: rx can2 id 1fffff44 len 8: 43 02 00 00 00 00 ff ff | C.......
> V (740618) can: rx can2 id 000 len 8: b6 78 00 00 00 00 00 00 | .x......
> V (740618) can: rx can2 id 000 len 8: ff fc 0f 03 ff 00 00 00 | ........
> V (740628) can: rx can2 id 000 len 8: ff ff ff ff ff ff 00 00 | ........
> V (740638) can: rx can2 id 000 len 8: 54 00 ff 00 00 00 00 00 | T.......
> V (740648) can: rx can2 id 1fffffbe len 8: 4d 02 00 00 00 00 ff ff | M.......
> V (740678) can: rx can2 id 000 len 8: 00 00 00 00 00 00 00 00 | ........
> V (740748) can: rx can2 id 1fffff44 len 8: 40 02 00 00 00 00 ff ff | @.......
> V (740818) can: rx can2 id 000 len 8: b6 78 00 00 00 00 00 00 | .x......
> V (740818) can: rx can2 id 000 len 8: ff fc 0f 03 ff 00 00 00 | ........
> V (740828) can: rx can2 id 000 len 8: ff ff ff ff ff ff 00 00 | ........
> V (740838) can: rx can2 id 1fffff13 len 8: 43 02 00 00 00 00 ff ff | C.......
> V (740848) can: rx can2 id 000 len 8: 54 00 ff 00 00 00 00 00 | T.......
> V (740878) can: rx can2 id 000 len 8: 00 00 00 00 00 00 00 00 | ........
> V (741018) can: rx can2 id 000 len 8: b6 78 00 00 00 00 00 00 | .x......
> V (741018) can: rx can2 id 000 len 8: ff fc 0f 03 ff 00 00 00 | ........
> V (741028) can: rx can2 id 1fffff44 len 8: 40 02 00 00 00 00 ff ff | @.......
> V (741038) can: rx can2 id 000 len 8: 54 00 ff 00 00 00 00 00 | T.......
> V (741078) can: rx can2 id 000 len 8: 00 00 00 00 00 00 00 00 | ........
> OVMS >
>> 30. des. 2017 kl. 18:24 skrev Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>:
>> OK, and as your log output was from your vehicle module, please also do…
>> level verbose
>> can can2 trace on
>> …before activating the bus.
>> Thanks,
>> Am 30.12.2017 um 18:22 schrieb Geir Øyvind Vælidalo:
>>> Can status gave this:
>>> CAN:       can2
>>> Mode:      Active
>>> Speed:     100000
>>> Rx pkt:                     104
>>> Rx err:                       0
>>> Tx pkt:                       0
>>> Tx err:                       0
>>> Err flags: 0x40
>>>> 30. des. 2017 kl. 18:13 skrev Geir Øyvind Vælidalo <geir at validalo.net <mailto:geir at validalo.net>>:
>>>> Fantastic! I’m in my car right now, so I’ll test it right now 🙂
>>>> Geir
>>>>> 30. des. 2017 kl. 17:59 skrev Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>:
>>>>> Geir,
>>>>> I've had a look into the mcp2515 driver and found some possible causes for your issue. Main possible cause would be there was no check or clearing of RX
>>>>> buffer overflows.
>>>>> There also was a chance the driver would read invalid frames, as the RX interrupts got cleared before the buffer content was fetched.
>>>>> I think I've solved those issues, and I also added retrieving the tx/rx error counts and flags, so "can status" can actually show you errors that occurred.
>>>>> I've got no simple means to check if my changes work and if they are more stable, I don't have a cable for can2/3.
>>>>> Can you please pull & test?
>>>>> Regards,
>>>>> Michael
>>>>> Am 30.12.2017 um 10:19 schrieb Geir Øyvind Vælidalo:
>>>>>> can can2 status gave me the same result. Once it stopped after receiving just 4 frames on Can2. During the few restarts I did this morning, 251 was the
>>>>>> most I got before it stopped.
>>>>>> Can1 recieved 50000 frames in no time and kept on going. It seems Can2 is the problem. Don’t know what happened yesterday when can1 stopped…
>>>>>> Geir
>>>>>>> 29. des. 2017 kl. 22:23 skrev Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>:
>>>>>>> Geir,
>>>>>>> can you check the output of "can … status" before and after death? Do the rx/tx counters still grow after death?
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 29.12.2017 um 22:14 schrieb Geir Øyvind Vælidalo:
>>>>>>>> I’m having problems with IncomingFrameCan when reading from two can buses from the Kia Soul. One of the can buses dies prematurely, and quite fast,
>>>>>>>> with no visible errors. Most of the time it is Can2 that dies, however that is not always the case.
>>>>>>>> I tried with an almost empty IncomingFrameCan2, containing just a counter to see how many times it is called, and it varied from 15 to  almost 200
>>>>>>>> before it dies.
>>>>>>>> This is the code:
>>>>>>>> RegisterCanBus(1, CAN_MODE_ACTIVE, CAN_SPEED_500KBPS);
>>>>>>>> RegisterCanBus(2, CAN_MODE_ACTIVE, CAN_SPEED_100KBPS);
>>>>>>>> void OvmsVehicleKiaSoulEv::IncomingFrameCan2(CAN_frame_t* p_frame)
>>>>>>>> uint8_t *d = p_frame->data.u8;
>>>>>>>> m_counter->SetValue( m_counter->AsInt()+1 );
>>>>>>>> IncomingFrameCan1 is quite verbose, but should not take too long time to process. But I have a lot of Polls on Can1:
>>>>>>>> static const OvmsVehicle::poll_pid_t vehicle_kiasoulev_polls[] =
>>>>>>>>     { 0x7e2, 0x7ea, VEHICLE_POLL_TYPE_OBDIIVEHICLE,  0x02, {  30,  30,  30 } }, // VIN
>>>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x01, {  30,  10,  10 } }, // BMC Diagpage 01
>>>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x02, {  30,  30,  10 } }, // BMC Diagpage 02
>>>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x03, {  30,  30,  10 } }, // BMC Diagpage 03
>>>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x04, {  30,  30,  10 } }, // BMC Diagpage 04
>>>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x05, {  30,  30,  10 } },// BMC Diagpage 05
>>>>>>>>     { 0x794, 0x79c, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x02, {  30,  30,  10 } }, // OBC - On board charger
>>>>>>>>     { 0x7e2, 0x7ea, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x00, {  30,  10,  10 } }, // VMCU Shift-stick
>>>>>>>>     { 0x7e2, 0x7ea, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x02, {  30,  10,   0 } }, // VMCU Motor temp++
>>>>>>>>     { 0x7df, 0x7de, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x06, {  30,  10,   0 } }, // TMPS
>>>>>>>>     { 0x7c5, 0x7cd, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x01, {  30,  10,   0 } }, // LDC - Low voltage DC-DC
>>>>>>>>     { 0, 0, 0, 0, { 0, 0, 0 } }
>>>>>>>> The few times that Can2 is the one that lives on, I can’t see any metrics from Can1.
>>>>>>>> Current source can be seen here: https://github.com/goev/Open-Vehicle-Monitoring-System-3 in case someone can take a look.
>>>>>>>> Any pointers to where I can start looking, or tips to what I can try?
>>>>>>>> Best regards,
>>>>>>>> Geir
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.teslaclub.hk
>>>>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171230/a11d0aba/attachment.htm>
