    Sun Dec 31 01:22:30 HKT 2017
Please send me:
can can2 status
Am 30.12.2017 um 18:20 schrieb Geir Øyvind Vælidalo:
> Hm… It didn’t fix the issues. Also, the MsgId looks messed up:
> OVMS >can can2 start active 100000
> Can bus can2 started in mode active at speed 100000Kbps
> D (80978) v-kiasoulev: M-CAN2 000 8 3c 00 f0 00 00 00 00 00
> D (80988) v-kiasoulev: M-CAN2 1fffff13 8 03 00 0c 1f 47 c0 ff f3
> D (80998) v-kiasoulev: M-CAN2 000 8 ff fc 0f 03 ff 00 00 00
> D (80998) v-kiasoulev: M-CAN2 1fffffbe 8 06 00 ff ff ff ff ff ff
> D (81118) v-kiasoulev: M-CAN2 000 8 54 00 ff 00 00 00 00 00
> D (81178) v-kiasoulev: M-CAN2 000 8 3c 00 f0 00 00 00 00 00
> D (81188) v-kiasoulev: M-CAN2 000 8 00 00 00 c0 ff ff 0f 00
> D (81208) v-kiasoulev: M-CAN2 000 8 ff ff ff ff ff ff 00 00
> D (81318) v-kiasoulev: M-CAN2 000 8 54 00 ff 00 00 00 00 00
> D (81378) v-kiasoulev: M-CAN2 000 8 3c 00 f0 00 00 00 00 00
> D (81398) v-kiasoulev: M-CAN2 000 8 00 00 00 c0 ff ff 0f 00
> D (81398) v-kiasoulev: M-CAN2 000 8 ff fc 0f 03 ff 00 00 00
> D (81518) v-kiasoulev: M-CAN2 000 8 54 00 ff 00 00 00 00 00
> D (81578) v-kiasoulev: M-CAN2 000 8 3c 00 f0 00 00 00 00 00
> D (81588) v-kiasoulev: M-CAN2 1fffffbe 8 4d 02 00 00 00 00 ff ff
> OVMS >
> As you can see, it still stops after few messages. Anything particular I should look into/test?
> Best regards,
> Geir
>> 30. des. 2017 kl. 18:13 skrev Geir Øyvind Vælidalo <geir at validalo.net <mailto:geir at validalo.net>>:
>> Fantastic! I’m in my car right now, so I’ll test it right now 🙂
>> Geir
>>> 30. des. 2017 kl. 17:59 skrev Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>:
>>> Geir,
>>> I've had a look into the mcp2515 driver and found some possible causes for your issue. Main possible cause would be there was no check or clearing of RX
>>> buffer overflows.
>>> There also was a chance the driver would read invalid frames, as the RX interrupts got cleared before the buffer content was fetched.
>>> I think I've solved those issues, and I also added retrieving the tx/rx error counts and flags, so "can status" can actually show you errors that occurred.
>>> I've got no simple means to check if my changes work and if they are more stable, I don't have a cable for can2/3.
>>> Can you please pull & test?
>>> Am 30.12.2017 um 10:19 schrieb Geir Øyvind Vælidalo:
>>>> can can2 status gave me the same result. Once it stopped after receiving just 4 frames on Can2. During the few restarts I did this morning, 251 was the
>>>> most I got before it stopped.
>>>> Can1 recieved 50000 frames in no time and kept on going. It seems Can2 is the problem. Don’t know what happened yesterday when can1 stopped…
>>>> Geir
>>>>> 29. des. 2017 kl. 22:23 skrev Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>:
>>>>> Geir,
>>>>> can you check the output of "can … status" before and after death? Do the rx/tx counters still grow after death?
>>>>> Regards,
>>>>> Michael
>>>>> Am 29.12.2017 um 22:14 schrieb Geir Øyvind Vælidalo:
>>>>>> I’m having problems with IncomingFrameCan when reading from two can buses from the Kia Soul. One of the can buses dies prematurely, and quite fast, with
>>>>>> no visible errors. Most of the time it is Can2 that dies, however that is not always the case.
>>>>>> I tried with an almost empty IncomingFrameCan2, containing just a counter to see how many times it is called, and it varied from 15 to  almost 200 before
>>>>>> it dies.
>>>>>> This is the code:
>>>>>> RegisterCanBus(1, CAN_MODE_ACTIVE, CAN_SPEED_500KBPS);
>>>>>> RegisterCanBus(2, CAN_MODE_ACTIVE, CAN_SPEED_100KBPS);
>>>>>> void OvmsVehicleKiaSoulEv::IncomingFrameCan2(CAN_frame_t* p_frame)
>>>>>> uint8_t *d = p_frame->data.u8;
>>>>>> m_counter->SetValue( m_counter->AsInt()+1 );
>>>>>> IncomingFrameCan1 is quite verbose, but should not take too long time to process. But I have a lot of Polls on Can1:
>>>>>> static const OvmsVehicle::poll_pid_t vehicle_kiasoulev_polls[] =
>>>>>>     { 0x7e2, 0x7ea, VEHICLE_POLL_TYPE_OBDIIVEHICLE,  0x02, {  30,  30,  30 } }, // VIN
>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x01, {  30,  10,  10 } }, // BMC Diagpage 01
>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x02, {  30,  30,  10 } }, // BMC Diagpage 02
>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x03, {  30,  30,  10 } }, // BMC Diagpage 03
>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x04, {  30,  30,  10 } }, // BMC Diagpage 04
>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x05, {  30,  30,  10 } },// BMC Diagpage 05
>>>>>>     { 0x794, 0x79c, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x02, {  30,  30,  10 } }, // OBC - On board charger
>>>>>>     { 0x7e2, 0x7ea, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x00, {  30,  10,  10 } }, // VMCU Shift-stick
>>>>>>     { 0x7e2, 0x7ea, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x02, {  30,  10,   0 } }, // VMCU Motor temp++
>>>>>>     { 0x7df, 0x7de, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x06, {  30,  10,   0 } }, // TMPS
>>>>>>     { 0x7c5, 0x7cd, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x01, {  30,  10,   0 } }, // LDC - Low voltage DC-DC
>>>>>>     { 0, 0, 0, 0, { 0, 0, 0 } }
>>>>>> The few times that Can2 is the one that lives on, I can’t see any metrics from Can1.
>>>>>> Current source can be seen here: https://github.com/goev/Open-Vehicle-Monitoring-System-3 in case someone can take a look.
>>>>>> Any pointers to where I can start looking, or tips to what I can try?
>>>>>> Best regards,
>>>>>> Geir
>>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171230/2b81df67/attachment.htm>
