[Ovmsdev] Modem link-drop crash
Sun Dec 24 14:53:59 HKT 2017
I found this patch from Espressif:
https://github.com/espressif/esp-idf/pull/1100/commits/6dd48547adbdaf89e43b680dc027e5aa786d9c0e <https://github.com/espressif/esp-idf/pull/1100/commits/6dd48547adbdaf89e43b680dc027e5aa786d9c0e>
They had only applied it to ‘master’, and not the ‘2.1’ branch we use. It seems to resolve the problem.
I also made some changes to the ovms_server_v2 to try to tear down the connection _before_ the ppp link goes down (but I now think these are unnecessary, although probably beneficial).
Can you guys try updating both your ESP IDF (based on open vehicles 2.1 repo) and ovms v3 firmware. See if it is more reliable? I will leave mine running now, to see if there is any improvement for long-lived connections.
> On 19 Dec 2017, at 5:14 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Hi folks,
> I left my module running with the modem connected (WiFi client off) for
> a couple of days. V2 server configured and connected, but the phone
> client was not running. The module was sitting on my desk (not in a
> car), powered from the high-power USB port on my laptop. It was
> blinking happily last night when I went to bed, but dark this morning.
> Apparently had crashed and rebooted during the night.
> Here's the trace-back from the screen. Looks like a link drop was the
> trigger, or perhaps the result of something else.
> Hope this helps,
> Greg
> I (129194054) ovms-server-v2: Send MP-0
> S47,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
> I (129194064) ovms-server-v2: Send MP-0
> D0,0,5,0,0,0,0,0,0,129191,0,0,0,0,0,0,0,0,0,0
> I (129795064) ovms-server-v2: Send MP-0
> I (129795074) ovms-server-v2: Send MP-0
> D0,0,5,0,0,0,0,0,0,129792,0,0,0,0,0,0,0,0,0,0
> I (130030624) simcom: CREG Network Registration: Searching
> I (130031414) simcom: Lost network connection (NetworkRegistration in
> NetMode)
> I (130031414) simcom: State: Enter NetLosGuru Meditation Error of type
> LoadProhibited occurred on core 0. Exception was unhandled.
> Register
> dump:
> PC : 0x4018f959 PS : 0x00060830 A0 : 0x8018a5d8
> A1 :
> 0x3ffd80f0
> 0x4018f959: ip4_route at
> /home/greg/esp/esp-idf/components/lwip/core/ipv4/ip4.c:223 (discriminator 2)
> A2 : 0x0000f01d A3 : 0x00000000 A4 : 0x00000000
> A5 : 0xfffffffc
> A6 : 0x3fff2c8c A7 : 0x00000014 A8 : 0x00000000
> A9 : 0x00000001
> A10 : 0x502b34ca A11 : 0x00000001 A12 : 0x3f42ea90
> A13 : 0x3f42eaa4
> A14 : 0x3ffda120 A15 : 0x00000000 SAR : 0x0000000b
> EXCCAUSE: 0x0000001c
> EXCVADDR: 0x0000f0d2 LBEG : 0x4000c2e0 LEND : 0x4000c2f6
> LCOUNT : 0xffffffff
> Backtrace: 0x4018f959:0x3ffd80f0 0x4018a5d5:0x3ffd8110
> 0x4018d3eb:0x3ffd8150 0x4018d40d:0x3ffd8180 0x4018d4ae:0x3ffd81a0
> 0x4018d90c:0x3ffd81c0 0x4018e46a:0x3ffd81e0 0x4018e4ab:0x3ffd8200
> 0x40196261:0x3ffd8220 0x4019882d:0x3ffd8240 0x40198874:0x3ffd8260
> 0x40199e9d:0x3ffd8280 0x40198764:0x3ffd82a0 0x4019a8f2:0x3ffd82c0
> 0x4019a92e:0x3ffd82e0 0x40196f25:0x3ffd8300 0x40199e9d:0x3ffd8320
> 0x40197e68:0x3ffd8340 0x40196149:0x3ffd8360 0x401b470c:0x3ffd8380
> 0x401825ad:0x3ffd83a0
> 0x4018a5d5: tcp_rst at
> /home/greg/esp/esp-idf/components/lwip/core/tcp_out.c:1336 (discriminator 4)
> 0x4018d3eb: tcp_abandon at
> /home/greg/esp/esp-idf/components/lwip/core/tcp.c:1630
> 0x4018d40d: tcp_abort at
> 0x4018d4ae: tcp_netif_ipv4_addr_changed_pcblist at
> 0x4018d90c: tcp_netif_ipv4_addr_changed at
> /home/greg/esp/esp-idf/components/lwip/core/tcp.c:1947
> 0x4018e46a: netif_set_ipaddr at
> /home/greg/esp/esp-idf/components/lwip/core/netif.c:452
> 0x4018e4ab: netif_set_addr at
> /home/greg/esp/esp-idf/components/lwip/core/netif.c:330
> 0x40196261: cifaddr at
> /home/greg/esp/esp-idf/components/lwip/netif/ppp/ppp.c:704
> 0x4019882d: ipcp_clear_addrs at
> /home/greg/esp/esp-idf/components/lwip/netif/ppp/ipcp.c:2192
> 0x40198874: ipcp_down at
> /home/greg/esp/esp-idf/components/lwip/netif/ppp/ipcp.c:2156
> 0x40199e9d: fsm_lowerdown at
> /home/greg/esp/esp-idf/components/lwip/netif/ppp/fsm.c:146
> 0x40198764: ipcp_lowerdown at
> /home/greg/esp/esp-idf/components/lwip/netif/ppp/ipcp.c:687
> 0x4019a8f2: upper_layers_down at
> /home/greg/esp/esp-idf/components/lwip/netif/ppp/auth.c:715
> 0x4019a92e: link_down at
> /home/greg/esp/esp-idf/components/lwip/netif/ppp/auth.c:701
> 0x40196f25: lcp_down at
> /home/greg/esp/esp-idf/components/lwip/netif/ppp/lcp.c:2341
> 0x40197e68: lcp_lowerdown at
> /home/greg/esp/esp-idf/components/lwip/netif/ppp/lcp.c:485
> 0x40196149: ppp_close at
> 0x401b470c: pppapi_do_ppp_close at
> /home/greg/esp/esp-idf/components/lwip/api/pppapi.c:355
> 0x401825ad: tcpip_thread at
> /home/greg/esp/esp-idf/components/lwip/api/tcpip.c:474
> Rebooting...
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171224/8b76be13/attachment.htm>
