[Ovmsdev] Modem LED control?
Tue Dec 19 15:37:43 HKT 2017
Greg,
the blue LED is not controllable, it's acting as a Zener diode in the voltage regulation, i.e. it flashes when draining a too high voltage.
So, as a workaround you could replace it by a standard Zener diode, just needs to have the same breakdown voltage.
But I don't think the black case lets through much light -- Mark?
Am 19.12.2017 um 05:47 schrieb Greg D.:
> Hi folks,
> The "real" module's case is black, but how well does it block light?
> I'm thinking about the modem's LED, which flashes pretty brightly in the
> proto (white) case. In a dark parking lot, it could attract unwanted
> attention. (Or, perhaps simulate a car alarm, which wouldn't
> necessarily be bad...)
> If the LED is visible externally, is there a way to disable it?
> Greg
