[Ovmsdev] chatty v2 server comms
Sun Dec 17 19:16:04 HKT 2017
That makes sense, I'll change the listener accordingly…
Am 17.12.2017 um 11:56 schrieb Mark Webb-Johnson:
> The “design” of the v2 peers check for environment is to send an environment message immediately the environment changes (when one or more apps are connected).
> It is meant to display a door opening, on a connected App, immediately the door opens, rather than having to wait a minute.
> But, it should only do the actual transmission if something in the environment -actually- changes. Perhaps that is the issue?
> I’m travelling for the next 24 hours, so won’t be able to check. Does the above “clue” help any?
> Regards, Mark
>> On 17 Dec 2017, at 6:42 PM, Michael Balzer <dexter at expeedo.de> wrote:
>> Tom,
>>> Am 17.12.2017 um 11:00 schrieb Tom Parker:
>>>> On 10/12/17 00:31, Michael Balzer wrote:
>>>> I fixed a minor bug in the v2 server code that caused much more data updates to be sent than necessary, can you please check if your data usage drops with
>>>> that fix?
>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/ca6f4200d6f40ab2e11e5cb6f2b7ec9d1ab33097
>>> I don't think changing from boolean to bitwise "or" would make a difference? I'm seeing a lot of messages, multiple per second, see below.
>> A logic or ("||") only gets evaluated up to the first "true", so it makes a difference if the function called does a modification -- IsModifiedAndClear() clears
>> the modifier bit.
>>> I think the problems are in components/ovms_server_v2/src/ovms_server_v2.cpp. In OvmsServerV2::ServerTask, the m_now_stat and similar logic will always be
>>> true in a real car. At a minimum we have 4 significant figures on the 12v measurement, and the park timer will count up every second.
>>> I changed the logic to only check once per minute and it's a lot less chatty, but this is probably not the right solution:
>> I agree, that doesn't look right…
>> OK, I found it: the frequent "D" updates are caused by the V2 server metrics listener setting m_now_environment to true on any (!) metrics change when peers are
>> connected.
>> I think these lines can just be removed from the listener:
>> if (StandardMetrics.ms_s_v2_peers->AsInt() > 0)
>> m_now_environment = true; // Transmit environment message if necessary
>> …as it checks for immediate update triggers (charge state etc.) before, and the main loop logic takes care of per minute update frequency when peers are connected.
>> Can you verify that?
>> A higher update frequency will only be needed for the location streaming mode (todo).
